Author Topic: PE400 1mm Oversize Piston Kits  (Read 7721 times)
ranchak
« on: February 27, 2010, 05:45:34 am »
I have the first run of PE400 piston kits in stock. These are a forged piston. A piston kit runs $199.99. Included in the kit is piston, rings, circlips,
wristpin, wristpin bearing and spacers. I have also added a gasket kit for
$69.95 and a clutch cover screw kit for $16.95. I also have gasket kits and screw kits
available for other model PEs. I will be adding a complete seal kit soon. If
there is interest I will add other fastener kits, fender, side panel, shock,
etc. Any suggestions? Thanks, Ron
Re: PE400 1mm Oversize Piston Kits
« Reply #1 on: June 24, 2010, 02:46:10 pm »
This is the Hot Rods 650 Sea Doo Rod kit that is used to replace the Discontinued rod from Suzuki. A very helpful fellow on the Yahoo Group PEmotorcycles figured out that this rod along with 4 thrust washers will replace the rod that is no longer available from Suzuki. We always try to supply OEM replacement parts when available, but this is a great way to get your PE400 back breathing fire again. This kit includes:
Rod
Piston Pin Bearing
Crank Rod Bearing
Crank Pin (Not used)
2 Large Thrust Washers (one used on each side of the rod)
4 Small Thrust Washers (two used on each side of the rod)
$120 bucks.
« Reply #2 on: March 15, 2011, 11:45:51 am »
Can anyone update this ? i have no idea where i got this info from , but have another guy after a rud kit for a PE400 1980 model?  what are you people using and were can i get one.
« Reply #3 on: March 15, 2011, 12:54:14 pm »
PE 400 rod and piston kits available here at Rons site
http://www.anchakandsons.com/info.html
We need stickys on this forum so common freauently asked for info is not burried!
« Reply #4 on: March 15, 2011, 03:56:48 pm »
freaky .....all parts are available in OZ . just use a Seadoo  " hot rod "  part 8117   shim the bottom so it is crank guide.
Serco have the specs ....as I have passed on the relevant imfo.
ranchak
« Reply #5 on: March 16, 2011, 05:08:22 pm »
Rod
Piston Pin Bearing
Crank Rod Bearing
$120 bucks.
The rod kit now comes with the OEM Suzuki crank pin
Le Canari
« Reply #6 on: March 16, 2011, 11:31:43 pm »
Rod
Piston Pin Bearing
Crank Rod Bearing
$120 bucks.
yes  i buy  one  set of cranck rod of pe400 to ron  and it is perfect
fabrice
ranchak
« Reply #7 on: March 17, 2011, 03:08:55 pm »
Merci Beaucoup mon ami!
Le Canari
« Reply #8 on: March 21, 2011, 10:11:20 am »
thank you ron  for french language :P
ranchak
« Reply #9 on: March 21, 2011, 04:06:02 pm »
I don't remember much more from High School
