Author Topic: how much fork oil for the square barrell  (Read 2845 times)
Offline paul
« on: February 23, 2010, 02:06:16 pm »
as above
090
Re: how much fork oil for the square barrell
« Reply #1 on: February 23, 2010, 09:42:44 pm »
200ml per leg. They also recommend 20-50 engine oil  :o
Offline paul
« Reply #2 on: February 23, 2010, 09:48:09 pm »
thanks bud ;)
« Reply #3 on: February 23, 2010, 10:16:37 pm »
Do you think they recommended 20-50 engine oil because it was pre fork oil days?
« Reply #4 on: February 24, 2010, 08:57:08 am »
20/50 motor oil worked great (best) in Husky mag250 forks after trying all the modern fork oils & viscosities. You just have to change it regularly.
« Last Edit: February 24, 2010, 05:03:45 pm by bigk »
« Reply #5 on: February 24, 2010, 09:34:28 am »
I've owned Maicos since 1970 and have never used anything other than ATF or Belray 15 grade fork oil and my forks work just dandy. I'd like to hear more about this 20-50 thing as it's never too late to try something different.
Brad are you talking about the external spring forks or the post '75 version?
« Last Edit: February 24, 2010, 09:42:29 am by firko »
090
« Reply #6 on: February 24, 2010, 07:22:59 pm »
Yes external spring aka square barrel. From my manual.
When did fork oil come in?
Wouldn't have been around in the early 70's.
« Reply #7 on: March 02, 2010, 12:01:05 am »
10 and 20 wt hydraulic oil and ATF have been around for ever Brad. I did some enquiries as to what other Maico guys use both here and in the US and it mostly came out the same as me every time. 10 or 15wt oil and 220-230ml in each fork leg.
