Author Topic: re pe 175 problem  (Read 5831 times)
Offline oldskool
re pe 175 problem
« on: February 21, 2010, 06:01:34 pm »
my pe 175 started making a popping noise and blowing smoke slowly got worse would start fine when it was warm but when it was cold wouldnt start,replaced spark plug started first kick,revs fine down low but when powerband comes on it starts dying like its flooded and blows smoke and is blowing oil out of exhaust which it hasnt done before still has good compression could this be the crank case seal? or maybe a carby problem? also the smoke smells different from normal 2 stroke smoke.cheers and thanx in advance gary
Re: re pe 175 problem
« Reply #1 on: February 21, 2010, 06:05:53 pm »
Smoke smelling different is a dead giveaway of blown seal on the gearbox side, have you checked how the level is?
Offline oldskool
« Reply #2 on: February 21, 2010, 06:22:53 pm »
no havent checked level yet im going to drain the oil tomorrow to see what bits i can find in there.is replacing the seal a big or expensive job.thanx tony cheers gary
Offline frostype400
« Reply #3 on: February 21, 2010, 07:26:14 pm »
Does sound like you have done a seal if I were you I would get the motor rebuilt completly rather than just replace the seal. :)
1971 tm400 and PE's
« Reply #4 on: February 21, 2010, 08:32:14 pm »
Requires cases to be split anyway to replace seal.
Offline frostype400
« Reply #5 on: February 21, 2010, 10:25:07 pm »
I have heard of guys not splitting the cases to put them in to fix it on the cheap they broke the old one and pulled it out and pushed the new one in but I would do the lot for peice of mind and it will be right for another 30 years. :)
1971 tm400 and PE's
« Reply #6 on: February 21, 2010, 10:29:40 pm »
the right hand side seal is fitted from the inside, so the crankshaft has to be removed.
Offline oldskool
« Reply #7 on: February 21, 2010, 11:07:42 pm »
thanx for the replies every body i think i will pull the motor out and send it to the doctors.i have very limited tools,space and knowledge so i think splitting cases and stuff is out for me.thanx again cheers gary
Offline oldskool
« Reply #8 on: February 22, 2010, 01:54:06 pm »
also can someone tell me were i would find the timing marks on the engine case to line up with the marks on the flywheel? ive explained my problem to a couple of mechanics and they seem to think the problem may be electrical either timing or cdi box,as the plug isnt getting oily and it has the popping noise like its firing at the wrong time.thanx cheers gary
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #9 on: February 22, 2010, 02:30:42 pm »
see the owners manual
http://cid-407d7ef0965d3991.skydrive.live.com/browse.aspx/Pure%20Enduro
you put your stator on with two screws. They are dead in the centre of the slot.
DONE.
It is becoming common with 30+ yr old stators that the coils are crapping out.
Take that to be rewound. CDI is unlikely to be a problem
But from your description of the problem,  I would be doing the seals.
Luke
« Last Edit: February 22, 2010, 02:33:28 pm by lukeb1961 »
Offline oldskool
« Reply #10 on: February 22, 2010, 02:52:06 pm »
thanx luke one mechanic said to take it to him and he will have a look hes usually pretty good ill get it to him tomorrow he will check it while its still in my ute and not charge for diagnosis.you always seem to know what your talking about so ill stick with seals.thanx luke have a good one cheers gary
Offline lukeb1961
    • PE175N
« Reply #11 on: February 22, 2010, 06:25:05 pm »
Just a thought - have you recently changed to ethanol-mixed fuel?
Ethanol destroys the seals in old bikes - wrong kind of rubber/plastics.
Luke
Offline frostype400
« Reply #12 on: February 22, 2010, 07:53:37 pm »
That sounds good Gary it is what I would do the gt80 motor is getting completly rebuilt now and then you know it will be right for another 30 years except it won't be ridden but just for peace of mind knowing it is right I will have to rebuild three 400 motors soon but I might have a go at them myself except for the performance mods I will get some one else to take care of those. :)
1971 tm400 and PE's
Offline oldskool
« Reply #13 on: February 23, 2010, 03:42:43 am »
probably is seals from your last post luke,ive been using the cheap 10 percent ethanol fuel from the servo :olooks like ill be changing fuel when it comes back.thanx again luke cheers gary
Offline oldskool
« Reply #14 on: February 23, 2010, 03:54:17 am »
yeh ide like to get full rebuild done frosty but funds a bit tight,not only is my bike broken but stuffed the head or head gasket on my ute.as i need the ute for work as well i have to put that first quotes have been from $700 to $2200 depending on what needs to be done to the head or if it needs a new head.done all this on my first week of holidays,what can i k#&k on my second week ;D.cheers gary
