Author Topic: bare metal finish  (Read 2958 times)
Offline misfit
bare metal finish
« on: February 21, 2010, 02:42:26 pm »
i have seen a few cars in magazines where people have sanded off all the paint and sprayed clear over the top as apposed to painting it a proper colour. i tried this method on some metal push bike bits i had lying around and they ended up going rusty. why is that? i cleared them straight after the paint was stipped off to not give moisture a chance of setting it. didnt work obviously
Re: bare metal finish
« Reply #1 on: February 21, 2010, 07:55:41 pm »
did you paint on a humid day? did you give the surface a wipe down with grease and wax remover?
Some of the bare metal hotrods I've seen in magazines are pretty rough in the flesh, and a few of them just rely on a rub with some steel wool and a spray with CRC/WD40 etc.
« Reply #2 on: February 21, 2010, 09:22:47 pm »
What sort of clear-coat did you use?
The cars that survive in bare metal use top quality 2-pak - and probably don't get left outside all that often....
Offline Sweep Rider
« Reply #3 on: February 21, 2010, 09:39:32 pm »
Hi,
I cleared my RM 465 frame some 12 months ago and all is fine. The only rust I have is where I have chipped the clear off.
I love the clear effect.  ;D
1974 TM 250, 1974 XL 250 Moto Sport, 1976 RM 370A, 1976 RM 125A, 1977 IT 250D, 1978 SP 370, 1984 XR 200R
Offline misfit
« Reply #4 on: February 22, 2010, 11:36:06 am »
i used septone clear in a spraycan. im thinking i may have to redo it on a dry day and just give it a wipe over with oil or wax or something
Offline crash n bern
« Reply #5 on: February 24, 2010, 11:12:39 am »
Autobarn will mix two pack paints into spraycans.
I was doing some repair work on my car and found surface rust under the paint.  Two painters told me that even if I paint it in acrylic I should undercoat in two pack primer as it will bite in and seal against moisture.
Por15 also make a clear that is designed to go over chrome and polished alloy to protect it.
