Author Topic: Mono shock wheel fit a twin  (Read 2597 times)
Offline jimson
  • Sanctuary point N.S.W
« on: February 16, 2010, 09:51:42 pm »
G'day viewers will a mono shock dt rear  wheel fit a twin shock without to much stuffing around ?  ;D jimson
Re: Mono shock wheel fit a twin
« Reply #1 on: February 18, 2010, 01:55:12 pm »
Cant see why not. is it the same width ?
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #2 on: February 18, 2010, 02:18:46 pm »
i thought everything we did was called stuffing around.
it should go pretty easily Jimson.
i take it it's to fit the bigger 250/360 bikes?
"flat bickie"
« Reply #3 on: February 18, 2010, 03:42:09 pm »
Offset is wrong - monoshock rim sits too far to the right.
If you fiddle with spacers to move it to the left, then you'll have chain alignment problems and the sprocket mounting studs hit on the swing arm.
You can move rim over by retensioning the spokes, but its not ideal.
Offline dt tas
« Reply #4 on: February 18, 2010, 10:15:02 pm »
hi just went to shed and checked my bike i did this last year i used twin shock spacers and brake, modified the swing arm where sprockets bolts was going to hit shorten sprockets bolts a bit .all works well and inline with front sprocket and in centre of swing arm yes can be done cheers George
