Author Topic: DT 125 or 175 motor. urgent  (Read 4998 times)
metalskin
« on: February 16, 2010, 03:10:36 pm »
WTB:  DT125 or 175 engine (chances of finding a 125 are slim to none i know) to suit '78 dt.
may consider a good complete bottom end as thats most of my problem.
description:  must be in reasonable order, needed a.s.a.p as the bike is my transport.
Price: negotiable (within Reason)
contact: pm, or ph 0401 624005.
« Last Edit: February 16, 2010, 03:15:24 pm by metalskin »
metalskin
Re: DT 125 or 175 motor. urgent
« Reply #1 on: February 16, 2010, 04:30:17 pm »
the prob with my engine seems to be the crank seal, i have a few seals here but only basic tools/no space etc..
and i really dont like touching gearbox's as i've had some bad luck in the past..
if theres anyone in melb who wants to earn a few bucks (or a couple of slabs?) i need these fitted.
or as above, need to find a replacement bottom end, or even complete motor.. pay a fair price either way,
just need to get back on the road.                                                           cheers, metalskin
« Reply #2 on: February 16, 2010, 08:20:26 pm »
Crank seals are under $50.
I have a Dt125/175 bottom end but they both need work.   I think you need to bit the bullet and pay someone to fix the one you have, be easier and less painfull.
Wasnt Tim754 looking for work ?
« Reply #3 on: February 16, 2010, 11:36:36 pm »
Arggg not that kind thanks Freaky.... ;) :D   (I have a crappy job at present :-[) Tim754         Freaky is right, get them done mate quick and your off flying again.
« Last Edit: February 16, 2010, 11:38:24 pm by Tim754 »
metalskin
« Reply #4 on: February 16, 2010, 11:42:02 pm »
i have a few seals for it, im pretty sure i have the transmission seal. witch is what i said in my last post, just need them fitted, but
i'd prefer to find a bottom end with no probs, as i dont trust this one... because i dont need time/space/crank splitter, it might be cheaper.
judging by the feel of it i would almost think 1 or 2 bearings have somehow exited their cages in tiny pieces and that is the metal in the
bottom end..
if anyone could do it, i would pay them.. just not a bike shop (thats if they'd even do it anyway.. most wouldnt).
i'd probably even buy a complete bike at the right price.                                               cheers, metalskin
mcmuffin
« Reply #5 on: February 17, 2010, 12:44:29 pm »
what about dt 175 85 model black red writing maybe 89 $1100 may need rebore ph 0425797029
« Reply #6 on: February 17, 2010, 01:06:07 pm »
I can sell you a 125 or a 175 motor ( 76) but you would still want to split the cases and put some new bearings in it and give it the once over.
MAins bearing with seals are $50
Rod kits are $60
LAbour $300 ?
Postage $200 ?
Do you see where im going with this.. the parts are cheap.   The tyranny of Postage and labour is what will kill you.
metalskin
« Reply #7 on: February 17, 2010, 01:11:11 pm »
Rod kits are $60
LAbour $300 ?
Postage $200 ?
if i was going to be doing any work... i'd be splitting my own cases.............. but im not after something that needs work...
« Reply #8 on: February 17, 2010, 03:41:37 pm »
Sorry bloke - both my spare bottom ends need rod kits (at least).
how long do you reckon you can live without the bike? Post your engine up, I'll fit some new seals and bearings, post it back - could probably get it back this time next week?
metalskin
« Reply #9 on: February 17, 2010, 04:54:09 pm »
thanks. i reckon it would be at least a week no matter where i get it done. if i cant find anyone local to do it for a decent price,
i might take up your offer. just out of interest, would gearbox/crank seals effect top end speed?  cheers, metalskin.
« Reply #10 on: February 17, 2010, 06:40:43 pm »
Leaking seals will hurt top end as you're not getting the correct mixture or amount of charge, a 2stroke is uses the bottom end to effectively pump the mixture into the cylinder so any leak means loss of power
« Reply #11 on: February 17, 2010, 11:28:35 pm »
While you have it apart it adds about 30 mins to the time and about $50 in replacing all the bearings, Just do it , then worry about it again in another 30 years.
metalskin
« Reply #12 on: February 18, 2010, 03:00:14 pm »
i just got quoted 2 to 3 hours labor, (@90hr) to pull it down for a quote.. i had to ask the guy,, you mean the whole job right??
no, he ment just to quote me and give me a pile of parts back if i dont want them to fix it. every place i rang, same old bs...
i've actually just found a cheap bottom end that is hopefully in good order, so i can probably have a go at rebuilding the original cases myself.
cheers for the replies/help/info/offers, much appreciate it. metalskin.
« Last Edit: February 18, 2010, 03:04:00 pm by metalskin »
« Reply #13 on: February 18, 2010, 03:26:58 pm »
Any mechanic that takes two hours to remove a DT125 engine, and split the cases, isn't worth $90/hour.
Offline Husk72
  • Attitude? What effing attitude?
« Reply #14 on: February 18, 2010, 04:55:45 pm »
I agree with Nathan,on that one.
But,jeeze $90 an hour?
I thought $70 an hour up this way was expensive,next time I'll be thankful.
                                               Cheers,Mark.
I used to drink a lot.
I still do,but I used to,too.
