Marketplace
Wanted
Wanted - Heavy Duty Springs for a YZ465G
Topic: Wanted - Heavy Duty Springs for a YZ465G (Read 2386 times)
Paddles
C-Grade
February 11, 2010, 10:00:53 am »
Wanted by a fat man (115kg and about 6 foot) with a 1980 YZ465, some heavier than stock springs for both the forks and the monoshock. The fork springs i could possibly chase down new, but the monoshock spring I'm finding impossible to get new so if someone's got something sitting in the shed that might be suitable and they want to sell it to me it'll help me out heaps. Thanks guys.
evo550
Re: Wanted - Heavy Duty Springs for a YZ465G
February 11, 2010, 12:18:06 pm »
Paddles,
You can run a "J" model spring on the earlier "G&H" shocks, it's a much stiffer rate due to the linkage set up,BUT, it is a straight rate spring not progressive of the cantilever shocks.
LWC82PE
Superstar
February 11, 2010, 05:39:49 pm »
I have got a used White Power shock spring off a 1982 YZ490 if its any use to you.
Length – 285mm
Number of coils - 10
Wire diameter – 11.3mm
$50 AUD for the spring plus shipping from storage in USA. I also have a lot more WP springs but im not exactly sure of their specs at this stage.
dalesween
B-Grade
February 11, 2010, 05:49:48 pm »
hey LWC,would that whitepower spring fit an it250k do you think?i heard they are 300mm long so should go close.
JohnnyO
Qld
Reply #4 on:
February 11, 2010, 05:51:05 pm »
Shock Treatment have the heavy fork springs, just measure the OD of your springs(38mm forks).
You'll probably need about .46kg springs.
Paddles
C-Grade
Reply #5 on:
February 15, 2010, 09:28:40 am »
thanks for the responses and pm's guys. i've gotta get the spring off the shock and measure it up but i think that it's longer than 300mm. i also need to check the id and od as well to clear the frame and the shock body.
zorroz
A-Grade
Reply #6 on:
March 02, 2010, 02:21:22 pm »
Check out this beauty:
http://www.vintagemx.us/cgi-bin/largephoto.cgi?C=5GHTr4Dd9WqQPJjJ
All Things 414
Reply #7 on:
March 02, 2010, 02:26:47 pm »
Nice!
Reply #8 on:
March 02, 2010, 02:31:43 pm »
it'd be a shame to put it into use where you couldn't look at it
Marketplace
Wanted
