Author Topic: 38mm triple clamps for leading axle Yamaha  (Read 9812 times)
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 38mm triple clamps for leading axle Yamaha
« Reply #15 on: February 12, 2010, 02:57:41 pm »
What are the forks off ?
my forks?
i'm not sure exactly. the Yammie brake backing plate fits up perfect, 1 pinch bolt on the right leg only,
38mm leading axle, drain plug at rea/bottom of leg with a "dummy" casting the same as the "drain plug" casting just above the drain plug. if that makes sense.
the forks ain't the issue for me.
38mm leading axle clamps to fit a Yamaha is what i need.
perfect if you can help.
"flat bickie"
Offline Husky500evo
« Reply #16 on: February 12, 2010, 10:30:52 pm »
http://ozvmx.com/community/index.php?topic=6549.0
The guy at the end of this thread seems to know his stuff . Freaky's forks look like YZ250/400D forks. Vandy's forks sound like YZ250/400E or F forks, because of the extra dimple.  But either set could be off something like an IT. I don't know my Yamaha parts that well .
Offline vandy010
« Reply #17 on: February 13, 2010, 01:33:30 am »
thanks for that Husky,
"flat bickie"
