Author Topic: 38mm triple clamps for leading axle Yamaha  (Read 9810 times)
Offline vandy010
  • #789 MX125a BMCC Brisbane
« on: February 09, 2010, 10:40:56 pm »
basically, i have 2 sets of forks and no clamps,
can anyone help out with a set of leading axle style triple clamps to suit the 38mm Yamaha forks?
i'm in Brisbane,
thanks in advance.
"flat bickie"
Re: 38mm triple clamps for leading axle Yamaha
« Reply #1 on: February 09, 2010, 11:07:38 pm »
Maybe... Need to go out to the shed and check.
If either of your sets of forks are YZ250/400D, then perhaps we could come to some sort of partial trade (obviously forks are worth more than triples)?
Offline vandy010
« Reply #2 on: February 09, 2010, 11:22:39 pm »
one set is 125j and the chrome ain't that good,
the other set {good chrome and i'm keeping} i'm not really sure what they're from, {the stauntion measures about 50mm shorter that my 36mm 125F does} and the Yammy front wheel bolts straight up to them.
i'll take a guess and say early IT.
"flat bickie"
« Reply #3 on: February 10, 2010, 09:42:34 am »
Most of the early ITs had 36mm forks - even the 250s and 400s.
The other give-away is the axle clamp.
Early ones have a single 8mm pinch bolt (YZ250/400D, and maybe E).
Most have a seperate plate that's held on by four 6mm studs (IT250/465, YZ125H/J, IT175J/K etc).
There's also a third type from the late 70s that have two 8mm pinch bolts (YZ250/400F, YZ250G, probably others).
Anyhow, none of that helps you get triple clamps. I'll go and check later this morning.
« Last Edit: February 10, 2010, 08:31:55 pm by Nathan S »
« Reply #4 on: February 10, 2010, 12:51:57 pm »
Where they those tripples Nat, ones in those 2 frames i send up to you last year ?  i reckon both had tripples and were like 36mm/ 38mm
« Reply #5 on: February 10, 2010, 02:07:23 pm »
The IT175E and the IT/YZ/DT hybrid? Both 36mm forks.
Offline vandy010
« Reply #6 on: February 10, 2010, 02:31:35 pm »
theseones i have just have the single pinch bolt on the right leg only.
thanks for the info so far Nathan.
i'm still keen.
"flat bickie"
« Reply #7 on: February 10, 2010, 03:29:11 pm »
all i knew was they werent 34mm   :O)
« Last Edit: February 10, 2010, 03:30:54 pm by Freakshow »
« Reply #8 on: February 10, 2010, 03:30:28 pm »
I have a set of forks here that look yamaha with a leading front be either 36/38mm good  chrome and legs, would swap for something i can actually use.
« Reply #9 on: February 10, 2010, 03:33:07 pm »
Pics Freaky?
« Reply #10 on: February 12, 2010, 12:46:52 am »
Note the little square block locator for the brake drum - might give iD
VAndy i also must have the tripple for these ones, if not i would have a set of TT500 alloy tops and bottoms, bought them for a TRick frame and the stems turned out to be half inch to short out the top, so wont be using them.
« Last Edit: February 12, 2010, 12:50:12 am by Freakshow »
Offline vandy010
« Reply #11 on: February 12, 2010, 03:16:40 am »
so are you saying you "have" a set of 38mm triples Freaky?
for "leading axle" Yamaha forks?
i'm interested.
"flat bickie"
« Reply #12 on: February 12, 2010, 07:12:41 am »
And after all that, I don't have a spare set of the triples you want Vandy. Sorry.
Freaky, I'm keen. Price?
Offline vandy010
« Reply #13 on: February 12, 2010, 09:31:18 am »
thanks for going to the trouble.
cheers!
"flat bickie"
« Reply #14 on: February 12, 2010, 02:49:39 pm »
So what are those forks off then ?
« Last Edit: February 12, 2010, 03:05:05 pm by Freakshow »
