Marque Remarks
British (BSA, Greeves, Triumph etc)
BSA SHOCKS
Topic: BSA SHOCKS (Read 2974 times)
jimson
Sanctuary point N.S.W
BSA SHOCKS
February 09, 2010, 10:07:25 pm »
G'day viewers I would like to know how long the shocks are on a BSA 441 scrambler please. jimson
Re: BSA SHOCKS
February 10, 2010, 07:17:56 pm »
does this help at all?
http://www.britishcycle.com/Products/hagon_shocks.htm
big mac
C-Grade
Re: BSA SHOCKS
February 11, 2010, 02:21:39 am »
If you are going to use the longer forks than standard in the B40 you will need longer shocks to compensate so it will stear, had to do this on my B44 as I was using ceriani forks.
bazza
Re: BSA SHOCKS
February 11, 2010, 07:08:57 pm »
Standard i had 355mm on mine, when i put the Bultaco forks and triples on i went to 370mm
Once you go black you will never go back - allblacks
Embrace patina
jimson
Re: BSA SHOCKS
Reply #4 on:
February 11, 2010, 08:53:21 pm »
How much clearance do you need for the back sprocket so the shock doesn't hit the bottom of the sprocket would a fat shock fit ?
jimson
Marque Remarks
BSA SHOCKS
