Author Topic: What's happening in CZ world?  (Read 9052 times)
Offline shortshifter
  • Sunshine Coast QLD
Re: What's happening in CZ world?
« Reply #15 on: February 15, 2010, 09:54:05 pm »
Good swapmeet find Brad.Good to see some pearls do turn up even nowadays.Is that a Husky polished tank?Just as an aside a question for you guys.Do your CZs have a bit of movement even when tightened up of the back wheel.The bearings are cz and seemed ok just on the axle without the backing plate.
090
« Reply #16 on: February 16, 2010, 12:10:41 am »
No its the later model cz tank.
With the rear wheel, check the housing to bearing situation. The housing may be flogged out. Mine was and John T. had to do a job on it.
« Reply #17 on: February 16, 2010, 04:26:39 pm »
I've had that happen as well, was the drum/sprocket side that had flogged out which I sleeved 1 night after work
