Clubroom
General Discussion
Clutch levers
Topic: Clutch levers (Read 1822 times)
Rossvickicampbell
Clutch levers
February 03, 2010, 01:16:59 am »
Guys - can you give me your opinion on easy pull clutch levers. Have only tried one cheaper one (as my clutch action is heavy as) and it basically did nothing. Would like to try something else but don't really fancy $100+ for something that doesn't work. Any experiences?
ta
Rossco
Tossa
Re: Clutch levers
February 03, 2010, 01:19:10 am »
try some exercise so you grow into a big strong man, then you'll be able to pull anything!!
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Rossvickicampbell
Re: Clutch levers
February 03, 2010, 04:21:14 am »
there is another opening there I will leave T?
090
Re: Clutch levers
February 03, 2010, 06:34:58 am »
MCS does one LA16LF. It has 3 different cable positions to change the ratio.
http://www.mcsonline.com.au/catalogue/ch_eight.pdf
Scroll down to near the bottom. I use it for my clutch and brake on my Maico.
Davey Crocket
Re: Clutch levers
Reply #4 on:
February 03, 2010, 08:22:07 am »
You can also buy Magura sets from Weekend Warriors for about $60.... real German steel....not Chinese or Tawanise. Rosco, have you extended the arm off the actuator?, thats the trick!
Rossvickicampbell
Re: Clutch levers
Reply #5 on:
February 03, 2010, 01:13:25 pm »
thanks Davey and Brad - don't think I can extend the arm on my 360 as it uses a push lever style setup. I'll go and have a look at what you have mentioned.
Rossco
Clubroom
General Discussion
Clutch levers
