Author Topic: DT250-360 frames  (Read 2379 times)
Offline Husk72
  • Attitude? What effing attitude?
DT250-360 frames
« on: January 27, 2010, 02:41:14 pm »
Guys,I've been told that the 1974 DT250 and 360 frames were the same size..I have both and can't see any difference between them.
Is this correct?
                                                   Cheers,Mark.
I used to drink a lot.
I still do,but I used to,too.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: DT250-360 frames
« Reply #1 on: January 27, 2010, 02:44:53 pm »
basically everything swaps over between the two frames.
so the frame number would be the only difference i'm aware of.
cheers.
"flat bickie"
« Reply #2 on: January 27, 2010, 03:22:17 pm »
vandy is right
they also have the same specs as the mx250/360 frame swing arm is longer
ps
whant a 360 motor to go in one mx or dt
Offline Husk72
« Reply #3 on: January 30, 2010, 03:42:12 pm »
Thanks for that Vandy and Jim.
I have a complete 360 with bad rust issues in the frame under the engine area.I also have a butchered frame that was used in a go-cart that is a 250,and it has the piece I need to replace rusted bit on the 360.
Whew,that solves the dilemma of finding and chopping up a perfectly good frame.
                                                Cheers,Mark.
