Author Topic: Rear Brake arm length Rm 125 1980 ( torque link)  (Read 2899 times)
« on: January 23, 2010, 06:44:03 pm »
As  stated above I need the length from  brake drum arm  to frame bearing centres.
« Last Edit: January 23, 2010, 07:21:01 pm by oldfart »
Offline Noel
Re: Rear Brake arm length Rm 125 1980 ( torque link)
« Reply #1 on: January 23, 2010, 07:12:20 pm »
With
(tape measure, while in place on bike, ie not dead accurate,)
530mm
Noel
« Reply #2 on: January 23, 2010, 08:04:37 pm »
Thank you for your reply Noel.   In comparison  Rm 125 -250 - 400 run the same torque arm length of  530mm centres.
250 & 400 are identical,  but the 125 is narrower at bearing mounts.     Mine must have a 250/400 arm with extra washers either side of bearing to make up difference which now makes sense.
« Last Edit: January 24, 2010, 10:14:11 am by oldfart »
