Author Topic: wanted rear speedway sprocket under 50 tooth  (Read 1408 times)
« on: January 23, 2010, 11:55:24 am »
hi
needed for my 465 long tracker a rear sprocket for speedway wheel.its a double sided wheel and a disc brake will be on the other side(need 1 of those as well)
i have colected most of the stuff now for this project
thanks
jim
Re: wanted rear speedway sprocket under 50 tooth
« Reply #1 on: January 23, 2010, 12:43:17 pm »
G'day Jim,
have you tried Titman's? fitting the rear disc to a rotatable speedway rear wheel sound like a challenge.
« Reply #2 on: January 27, 2010, 01:13:27 am »
You pay a buck a tooth from Gopher Glass in the US, they also have the cut out and drill to slide straight on the Barnes and kennedy competiton hubs.  Cheaper than going the titman route then paying the $35 to get the hole in the centre cut.  IS it a speedway blank also try ASi in adelaide
« Reply #3 on: January 28, 2010, 08:39:11 pm »
its for a speedway wheel double sided,to go in my longtrack bike
« Reply #4 on: January 29, 2010, 11:57:25 am »
THen speak to either.  But be $56 from Gopher man
IT400C
« Reply #5 on: January 29, 2010, 01:02:59 pm »
I'd recommend John Titman - he's an ex-speedway rider himself, so he'll understand exactly what you're talking about.
He was runner up in the Speedway World Championships a couple of times in the '70's.
