Author Topic: RM370 and RM400 Oversize Pistons  (Read 9690 times)
ranchak
« on: January 20, 2010, 08:04:52 am »
Hi Guys, I'm thinking about reproducing oversize pistons for the RM370A,B and the RM400N,T. I wanted to get some feedback to see what you guys thought about this. I'm thinking I will do a 1.5mm and 2.0mm oversize. Any suggestions or input? Thanks, Ron
Re: RM370 and RM400 Oversize Pistons
« Reply #1 on: January 20, 2010, 10:50:53 am »
There is another make & model piston which slots straight into those bikes and are readily available, so I think you should maybe try to take orders before you get a run done.
« Last Edit: January 21, 2010, 08:46:21 am by bigk »
DR
« Reply #2 on: January 20, 2010, 01:58:09 pm »
if there's a piston larger than 80.50mm with an 18mm pin that'll slot straight into the RM400's I'd be interested to know what it is :-\ Has always been a bit of an achilies heel for the big RM's only having 2 genuine oversizes 0.25 and 0.50. The pistons are around but the 0.50 rings are very scarce and can't be replaced as often as desirable. Surprises me wiseco or someone didn't make them but they didn't. Depending on price I'd be interested in a 1mm over for sure..starting at 1.50 over would seem to be losing an overbore..maybe 1.00mm and 1.50mm over would be the ticket ;)
Offline Viper79
« Reply #3 on: January 20, 2010, 02:15:29 pm »
Doc,
Rick Horvat in the states had Wiseco 1.00 + pistons for the RM400 N/T available, I bought one in 2003 and have it stashed away just incase.
There is accasionally an advert in the VMX magazine for him in the new products section near the back.
Regards
Rob.
QA50 KO, XR75 K5 Race bike from VMBA days, XR400R1, CRF450R3, RM400T, DR650SE with off road adventure mods, MX360A, YZ400D, YZ465H, IT250H, 1985 Jawa 897 Slider, 2016 Jawa/GM Slider
« Reply #4 on: January 20, 2010, 03:28:02 pm »
You will probably want to make 1mm oversize pistons first before going to 1.50 otherwise thats skipping a size where you could get more life out the barrel.
Are the +1mm PE400 pistons ready yet???
ranchak
« Reply #5 on: January 20, 2010, 03:31:08 pm »
Leith, the PE400 pistons should be in around the second week of February.
ranchak
« Reply #6 on: January 20, 2010, 03:32:53 pm »
Rob, I know Rick has oversize pistons, but I thought since I have a webstore it would be easier for you guys.
Offline Viper79
« Reply #7 on: January 20, 2010, 03:41:43 pm »
Sounds good, from memory it was a bit of a task to get one from him. I was fortunate enough to have a brother on hollidays over there who could bring it back with him.
ranchak
« Reply #8 on: January 20, 2010, 05:33:08 pm »
Rob, have a look and see what you think needs to be different or added:
www.anchakandsons.com
Thanks, Ron
DR
« Reply #9 on: January 20, 2010, 06:04:34 pm »
ranchak that looks bloody good..I'd shop there! 8) I'd reckon if you added repro TM125/RM125M/S magneto covers you'd clean up ;)
Offline Viper79
« Reply #10 on: January 20, 2010, 07:00:45 pm »
Looks great as it is Ron.
ranchak
« Reply #11 on: January 21, 2010, 03:48:53 am »
Thanks for the positive feedback guys. I'm trying to add items that you guys need. I do alot of business with blokes in Australia, New Zealand and South Africa, it's important to me to find out what you guys want or need. I will be adding:
   swingarm bearing kits
   more reproduction gaskets (RM and PE)
   reproduction chain buffers
   more engine parts
   reproduction pistons
 I have alot of parts that are not listed, I need to get busy and add them to the store. I was thinking about changing the layout of the store. Maybe have seperate headings for each year/model? This way if you have a RM400C you can see with one click what we have available for that bike.
Offline cz400
« Reply #12 on: January 23, 2010, 06:28:30 pm »
anybody know where to source a rod kit or a rod that suits a 370,cheers
Offline crabman
« Reply #13 on: January 25, 2010, 06:30:46 am »
Hi from South Africa
I am looking for a complete rod kit, big end , piston, gaskets and seals for an RM 370 B . I am also lloking for a rod kit of a 1983 CR 480 Honda.
Please email me more info [email protected]
Crabman / Gavin williams
Old and slow - and happy
« Reply #14 on: January 25, 2010, 08:48:51 am »
www.bbimporters.com.au should have one from something else that will match up dimensionally and fit
for example a Sedoo rod goes in PE400 and Skidoo rod goes in PE250
