Author Topic: dt125 forks /31mm forks or whole front end  (Read 2715 times)
metalskin
« on: January 19, 2010, 12:23:38 am »
wanted: 78 dt125 forks or something that will fit.
contact: pm.
im after a some dt125 forks or possibly any 31mm forks that will fit, would consider disk front end.  needed by friday morning for rwc.
« Last Edit: January 22, 2010, 05:57:07 pm by metalskin »
trailietrash
Re: dt125 forks /31mm forks or whole front end - asap
« Reply #1 on: January 19, 2010, 07:12:39 am »
If it will help.... early Honda SL and XL 125/185 forks were 31mm with 12mm axle. CT125 and later XL models had leading axle forks again with 12mm axle.
« Last Edit: January 19, 2010, 07:14:49 am by trailietrash »
« Reply #2 on: January 19, 2010, 12:19:45 pm »
Nothing like leaving your run late.
I got a set here but wont help you by Fri,  can you just borrow some and then give tyhem back after it passes ?
metalskin
« Reply #3 on: January 19, 2010, 01:28:30 pm »
i have to get it done by friday, or my bikes rego will get canceled. so i cant do it 'some other time'
thanks for the offer anyway.. not trying to leave anything till the last minute, but it should of passed a rwc..
will ring around a few more wreckers and see what turns up but i cant even get parts to fix the forks
without ordering them in, so the only way it is possible to fix my prob by friday is a 2nd hand set/front end.
« Reply #4 on: January 19, 2010, 01:32:23 pm »
Whats actually wrong with them ?
Some one can lend you a front end im sure, just to get it over the line.  Keep asking and psot up where you are so people can see how close you are to be able to help.
metalskin
« Reply #5 on: January 19, 2010, 02:02:12 pm »
i am in melbourne. 5 min from the city.
something in the dampening stuff.. springs, seals and oil level are all fine. just feels squishy and wont rebound properly.
« Last Edit: January 19, 2010, 02:04:07 pm by metalskin »
Offline Canam370
« Reply #6 on: January 19, 2010, 02:13:37 pm »
Try putting a preload spacer on top of the springs. That should give you the rebound to get past the RW if thats all the problem is. Sounds like the springs have sagged out.
metalskin
« Reply #7 on: January 19, 2010, 02:23:39 pm »
i will look into it but my springs seemed fine.
Offline Canam370
« Reply #8 on: January 19, 2010, 02:33:08 pm »
Its going to be either a bent fork, too heavy oil or sagged springs. Not much to go wrong with those forks.
DR
« Reply #9 on: January 19, 2010, 04:12:37 pm »
'if' the wrong width axle spacers are fitted this can cause binding in the forks, especially if the spacers are not wide enough and the forks are pulled together when the axle nut is tightened. Just a thought...
metalskin
« Reply #10 on: January 19, 2010, 04:34:52 pm »
will check it now.  i have been told by a couple of places just chuck some more oil in it,
preferably a heavy grade engine oil. although i dont know if that is a good idea.. would the seals hold up?
Offline Canam370
« Reply #11 on: January 19, 2010, 04:45:41 pm »
Putting in heavier oil is only going to make the rebound situation worse. Too much oil can cause the seals to leak with use. Just use the specified quantity and viscosity.
