Author Topic: XT250 - Tip Find  (Read 7354 times)
Offline Colin Jay
XT250 - Tip Find
« on: January 16, 2010, 01:33:48 pm »
Yesterday I was at the local rubbish tip when the supervisor, who knows I'm a bike nut,  came up to me and told me that there was an old Yamaha trailbike with gold rims down at the Rynie tip (another sit operated by the local council 30km away). My thoughts were that it would be the ultimate in good luck for it to be a late model XT500, but more likely that it would be an early 80's XT250. So I was at the gate waiting for Rynie tip to open this morning, and here it is;
Yep, it's a 1981 XT250H and it cost me $20, which was what supervisor and I agreed would be it's scrap value. Except the picture does lie, there were no front forks with it. The forks that are fitted are a pair of XT250 forks that I happened to pick up from my younger brother a few years ago. I knew they would come in handy one day!
The engine would not turn more than about 300 degrees, and we all know what that generally means. Yes, a bent valve.  So, it was off with the head, and this is what I found;
So the question is what to do with it? Well I can probably get a seat, tank and some guards from the wreckers that I frequent. The engine is repairable, it needs the head fixed, new piston and camchain. The camshaft and exhaust rockers are worn but thats not a real problem, and I also have a 34mm Mikuni Carbie that I can fit.  My thoughts at present are to make it into an enduro bike to replace the XT500 that I currently race. With a bit of head work, a hot cam, maybe a big bore kit and the 34mm Mikuni from my parts box, I should be able to extract a bit more go from the engine.
When I pulled the top end off, I found that the camshaft looks to be the same as the XT/TT/SR 500 camshaft. I don't know if they actually are and will have to do a bit of research. If it is the same came I will be in luck as I have a few spares, including some hot ones.
Has anyone had any experience of hotting up one of these engines? Are big bore kits, available, and what cams do people use / recommend?
CJ
Offline mboddy
  • Canberra
Re: XT250 - Tip Find
« Reply #1 on: January 16, 2010, 02:22:12 pm »
There would have been a xt200 at my local tip but my work mate told him 'don't take it to the tip - Mark will pick it up'.
So now I have a xt200 complete in bits.
Vinduro Penrite Team
« Reply #2 on: January 16, 2010, 06:19:06 pm »
col
i know of some one who got 1981 xt500 complete from the tip bought as scrap value.alloy tank was damaged when dumped out of the skip in which it was dumped in
« Reply #3 on: January 16, 2010, 06:46:09 pm »
There is a whole thread on these early TT/XT250's in the yamaha section on here but i can not remember the title of the thread. Should be a fair bit of stuff on ebay for them. Heres an ignition unit
http://cgi.ebay.com/YAMAHA-XT250-XT-250-SR500-SR-500-XT500-XT-500-IGNITION_W0QQitemZ150403606036QQcmdZViewItemQQptZAU_Motorcycle_Parts_Accessories?hash=item2304c0e614
« Last Edit: January 16, 2010, 06:49:34 pm by LWC82PE »
Offline jimson
  • Sanctuary point N.S.W
« Reply #4 on: January 16, 2010, 07:21:32 pm »
Its good to see someone else does there shopping at the tip I've bought a Indian ME125 ' Suzuki TS125 ' kawasaki F11  ' honda XL 250 From my local tip. ;D  jimson
« Reply #5 on: January 16, 2010, 11:55:08 pm »
i saved a ts250a and ts185a from going out to the tip to be sold as scrap,the 250 even had new chain/spockets,knobby types/gearlever and brake shoes,bargin!!and they both ran with abit of work
