Author Topic: TM125 Vs TF125 cases  (Read 2846 times)
Power Stand
« on: January 15, 2010, 03:55:10 pm »
Advice needed?
Are the crank cases off a TF125 the same as a TM125? Got a friend that’s restoring a TM125 and he heard that the cases are compatible; the main bearings slipped/ fell out the TM.  I guess date ranges may be a factor.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: TM125 Vs TF125 cases
« Reply #1 on: January 15, 2010, 05:16:23 pm »
Advice needed?
Not the same at all, the TF is crankcase reed induction. 73-75 TS125, RV125 and TC125 are interchangable with the TM125
Ban BLACK rims NOW
« Reply #2 on: January 15, 2010, 05:32:50 pm »
TF125 is the same as TS125 about 78/79 onwards or the ER models.
Power Stand
« Reply #3 on: January 15, 2010, 08:18:44 pm »
Thanks guys, will pass on the info. :)
« Reply #4 on: January 19, 2010, 12:35:04 pm »
The TC125 cases should be the last used as the High/ Low ratio bits on the left side can be a pain. ;)
