Author Topic: fibreglass seat base  (Read 3337 times)
Offline jimson
  • Sanctuary point N.S.W
« on: January 11, 2010, 11:23:33 pm »
G'day viewers just wondering what mat do I use if I was to make a seat base out of fibreglass  ::) jimson
Re: fibreglass seat base
« Reply #1 on: January 11, 2010, 11:50:57 pm »
Woven glass
« Reply #2 on: January 12, 2010, 03:09:32 pm »
If your going to make amould then the item use chopped strand as it's cheaper. A good technique is to wrap either glad wrap or the brown packing tape over what you want to glass and wet lay-up directly on that
HTH
Offline jimson
« Reply #3 on: January 12, 2010, 09:47:16 pm »
Lozza the chopped strands are they the fury like bits your talking about I've used that before in the floor of a car for rego but I thought the mat would be stronger  :-\  jimson
« Reply #4 on: January 13, 2010, 12:00:09 am »
It comes in different 'weights' and the thickness of the item and how well it's layed up makes it resiliant not the actual weave. Although you can lay up the cloth in a 'bi-axial' pattern one layer straight, next at 45deg, next straight.next 45 deg etc etc which is sort of what chopped strand is doing anyway.
« Reply #5 on: January 13, 2010, 12:21:14 am »
 BEst bet is you speak to matcho mick direct, he'll set you on the correct tech for your progect.
Offline matcho mick
    • Moto Tumbi
« Reply #6 on: January 14, 2010, 09:14:03 pm »
i'm back, ;D,(fugging compootas :-\),use either Chopped Strand Mat,or Single Strand Mat for the layups,required thickness depends on seat supports,your actual body weight,whatever!,back the mat with a final layup of woven cloth for strength/looks,basically csm/ssm has random strength,woven cloth is unidirectional in strength,hth? :P
