Author Topic: foot pegs  (Read 15889 times)
foot pegs
« on: November 20, 2007, 07:51:39 pm »
Has anyone got any close up photos of the modern 91 onwards RM foot pegs on 79/80 RM/PE 250/400?  As I mentioned here http://ozvmx.com/community/index.php?topic=833.0 I came across some difficulties and want to see how you other guys have done it. I’ve bushed the pegs back to 8mm with no problems. The left side spring doesn’t reach the pin on the frame. I've worked out I can reposition the pin, or is there a longer spring that I should be using instead of the spring that goes with the modern RM left peg?. The real big problem I’ve got is that the kickstarter comes down and bangs right on the corner tip where the right side spring clips into the peg and also partly hits the spring. Have other people had this problem? What did you do to fix it? Ive sort of got my own idea but I’m not convinced it’s the best way to go. I was hoping these would have been a little easier to fit. Any help is appreciated thanks
Re: foot pegs
« Reply #1 on: November 21, 2007, 12:12:01 am »
i got no furthe rthan keeping my eye out for a set of Rm pegs to suit the TM. soz can be no help yet....
Re: foot pegs
« Reply #2 on: November 29, 2007, 08:24:38 pm »
I had a read of the RM N/T article in issue  14 of VMX and Andrew from MonsterRacing (does that business still exist?) said aftermarket pegs fit those RM’s
Does anyone know who makes or where you can get aftermarket pegs for 79/80 RM’s?
I’m thinking this may be a better option than trying to fit 91 onwards RM pegs as they would be a perfect fit with no mods required.
I think someone told me ages ago GMC makes some but I think they were quite expensive. Before I email him for photos/price etc I want to know if there is any other options available, maybe from Vintage Iron or some place? There seems to be decent aftermarket pegs available for Maicos and a few other brands but I haven’t seen any for RM’s yet
My preference is for stainless steel pegs. What are the mid to late 80’s RM pegs like? Would they fit on all right and are they any better than the originals? That would probably be the cheapest option but I doubt you can get them made from SS.
just checked vintage iron the but nothing for suzuki. they got nice ones for husky. maico, CZ though
Any info would be apprieciated.
Re: foot pegs
« Reply #3 on: November 29, 2007, 09:11:38 pm »
look at these http://www.amsracing.com/foot_pegs.html
none for suzukis though :(
my next stop - will be vintage suzuki, maybe success there.
Re: foot pegs
« Reply #4 on: November 29, 2007, 09:25:28 pm »
Someone back in the old thread had the good oil on them ???  was it pit bike pegs
« Last Edit: November 29, 2007, 09:31:02 pm by oldfart »
Re: foot pegs
« Reply #5 on: November 29, 2007, 11:38:30 pm »
I just sent my YZ pegs to Geoff as I could not find aftermarket replacements.  The job he did was nothing short of excellent and I actually thought around the same price as some US ones I had seen for my CR - better deal when you factor in time and freight etc?  He used the stubs and put new pegs on mine - great quality and also BIG!!!!
great job
regards
Rossco
Re: foot pegs
« Reply #6 on: November 30, 2007, 07:10:17 pm »
it looks like it will have to be GMC as i havent found anthing else YET. i cant believe theres so many for Maicos but nothing for RMs and they have got what i would call very poor stock pegs. i looked in some 85 RM brochures ive got and the pegs on those dont look much better than the earlier ones so not real point in getting those.
Re: foot pegs
« Reply #7 on: December 06, 2007, 07:38:07 pm »
Ive spoken to GMC about his footpegs and he only does ones for TM’s but he said from his info they should fit 79-86 RM’s and PE’s. So before buying I would need to do some more research to make sure they would work as I wouldn’t want to pay $165 and then find out they don’t fit. But if any one has them on a 79/80 RM and can tell me they are a good fit and use the stock springs then they should be right for my bike. Next issue, he cant make any till end of January and I really wanted some before the end of the yr so I can get them fitted to my frame a make sure they fit ok and do a dry assembly before blasting and painting it as I don’t want to get it painted and find things still are not right and welding/grinding needs to be done after ive got it painted.. So this whole pegs drama is holding things up for me. I work in then trade and know what its like to be extremely busy so there’s no way I’m going to put pressure on GMC to make me a set asap. So in the meantime I’m still prepared to search around.
I’ve had no success with Vintage iron, Rage racing, Vintage Suzuki or AMS racing but I thought it was worth while inquiring to AMS since they had such a large range for other bikes but am waiting on reply.
Does any one else know of any other specialist vintage places I could try?
Surely there is some other places that make pegs for old RM’s or even mid 80’s RM’s.
I found a photo of a RM 250 T on the Pro Form pipe site and it has some different pegs on it but the photo isn’t close up enough to really see what they are.
Another thing ive just noticed is that the 79/80 has different RH peg mount to the 80/81 PE so im wondering if that could have been the cause of my problem of the new 91 onwards RM pegs not quite positioned out wide enough and the kick starter hitting the spring right on the corner of where the spring hooks in. Andrew from Monster racing said he didn’t have this problem with RM 400 79/80 so I’m now wondering if its differences in the RH peg mount or kick starters or how the RM 400 motor sits in the frame.
My next idea is to go back to the idea of using the new RM pegs and get a 79/80 RM 250/400 RH pegs mount to see if that makes a difference. I cant see why it would be different to the PE mount though. You can see the part numbers below.
Has any one got an old peg mount off 79/80 RM 250/400 they can give me or lend to me? I would just need to borrow it to compare to my PE peg mount and then I can return it.
Another idea ive come up with is using pegs from late 80’s to about 1990  off RMX/RM as they still used the same springs as the PE’s and old RM’s but the in 91 they changed to the newer style springs which ive got. I would imagine RM/RMX pegs from 88-90 still are not that good but I haven’t found anyone who makes aftermarket replacements for them yet. They all start from 91 onwards models.
Part # = 43510-40600
Part Description = HOLDER,FRONT FOOTREST,RIGHT
Model Count = 4
PE250T 1980 246 PE250 DUAL PURPOSE
PE250X 1981 246 PE250 DUAL PURPOSE
PE400T 1980 397 PE400 DUAL PURPOSE
PE400X 1981 397 PE400 DUAL PURPOSE
Part # = 43510-40401
Model Count = 4
RM250-N 1979 246 RM250 OFF ROAD
RM250-T 1980 246 RM250 OFF ROAD
RM400N 1979 417 RM400 OFF ROAD
RM400T 1980 417 RM400 OFF ROAD
Re: foot pegs
« Reply #8 on: December 06, 2007, 08:33:06 pm »
Just grab some Rhs and weld it to the frame  ;D  Or do what i do just sit on the bike and ride it about  :P
Re: foot pegs
« Reply #9 on: December 06, 2007, 09:18:02 pm »
posted is a pic of a PE 400 RHS foot peg
[attachment deleted by admin]
Re: foot pegs
« Reply #10 on: December 06, 2007, 09:26:19 pm »
Problem spring in view  :)
Re: foot pegs
« Reply #11 on: December 06, 2007, 11:22:41 pm »
Look at the pit bike suppliers they have plenty of nice wide pegs and for $22 a set they are worth a look.
Re: foot pegs
« Reply #12 on: December 07, 2007, 10:51:18 am »
have you had a look yet at the IMS website - www.imsproducts.com - they carry Suzy pegs back to 91 and have some good pictures to check out fit maybe?
Rossco
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Ban BLACK rims NOW
Re: foot pegs
« Reply #14 on: December 08, 2007, 03:33:17 pm »
The TM pegs had a thick single flat bar type mount on the frame & the peg had 2 flats that sat over it.
The 77-78 RM pegs were of the more conventional style of 2 flats on the frame and the peg sat between them.
Then 79- 86 they went back to the TM type mount but with a spring fitted underneath the peg & over the bolt
Not sure about other years.
This peg was made for a TM but I am certain it fits RM's with the same peg mount style. Obviously if it didn't fit as I expect it to then I would refund the price on return.
