Author Topic: 73 400 crank  (Read 4335 times)
Offline hampster
73 400 crank
« on: January 06, 2010, 09:49:02 pm »
Hi,
Just pulled apart my second 400 bottom end for parts to finish my first 400 and the crank i was going to use has had water sitting in the crank and it has got under the bearing position and has rusted it past repair, dam***
So has any one in cz land have a 73 400 crank for sale or i can swap a fully rebuilt 400 70 -72 style crank.
Thanks Chris.
Re: 73 400 crank
« Reply #1 on: January 06, 2010, 10:30:31 pm »
chris
why cant you you use the early crank.is not the only difference the wodruff key on the later drive side.also i had my cr250 speedy sleeved onthe shafts it works perfectly.if you must send my your email addy and i will send the guys email in nevarda who has some.
jim
090
Re: 73 400 crank
« Reply #2 on: January 06, 2010, 11:27:59 pm »
Is that the difference? Woodruff key size?
Offline Tankslapper
    • Hydrosteer
Re: 73 400 crank
« Reply #3 on: January 08, 2010, 05:36:39 pm »
I thought 73" has flycut weights versus 71" full circle ????
Re: 73 400 crank
« Reply #4 on: January 08, 2010, 06:48:34 pm »
yes i think you are right the early has full circle ,
Re: 73 400 crank
« Reply #5 on: January 10, 2010, 01:45:33 pm »
Thats correct about the full circle versus cutouts but would be pretty sure that they would be interchangeable
Offline hampster
Re: 73 400 crank
« Reply #6 on: January 13, 2010, 06:52:19 pm »
That's right but they have a different final drive with the full circle being a taper and the pork chop being a key way.
