Author Topic: YZ125C fork legs  (Read 5600 times)
Re: YZ125C fork legs
« Reply #15 on: February 01, 2010, 11:36:10 pm »
Its the same stud pattern as the Dt2mx if that helps Nath.
Because its on the FT bike it can have a bit of a bend in it as im using sock filters, but this one has a little bit too much as the filter sits agains the frame ans the new filter i got is a little longer than the last ones and made the problem noticable.
Anyone got a DT2mx inlet or if a later one fits that pattern please advise.     John what did you do with that one on the MXb you where taking bought wrecking ?
