Author Topic: yz250 a/b tank  (Read 26288 times)
Offline k2000x
yz250 a/b tank
« on: December 28, 2009, 06:43:34 am »
alloy yz250 tank a couple of small dents. paint stripped, with cap but no taps $300 ono
Re: yz250 a/b tank
« Reply #1 on: December 28, 2009, 08:51:58 am »
I'm keen, is it an A or B, I think they are different.... B has fat monoshock inside it. Is there any color left on it? might give a clue any way I'll pm you, Cheers John.
Re: yz250 a/b tank
« Reply #2 on: December 28, 2009, 09:04:37 am »
pm sent.
Re: yz250 a/b tank
« Reply #3 on: December 28, 2009, 03:11:01 pm »
if it is a B one I am interested and Davy is right - the A and B are different so depends on which one it is.  I don't mind the no paint and tap either?
regards
Rossco
Offline k2000x
Re: yz250 a/b tank
« Reply #4 on: December 28, 2009, 03:27:47 pm »
it was white and yes it has no bolt wholes it was held on by straps as the paint was rubbed of were it went before i stripped it to see if it was full of bog. at front of tank it has dowl on each side that slid into mounts on frame... i purchased a twin shock yz a and the first mono shock yz250 and they came with 3 spare tanks it has a number under it 5012806 this is the last one i have as i used the rest on my hl500 and a spare race tank...i will post some picks
Re: yz250 a/b tank
« Reply #5 on: December 28, 2009, 06:02:35 pm »
then it is a B tank.  Davy you were in before me - is it one you are looking for?
regards
Rossco
Re: yz250 a/b tank
« Reply #6 on: December 28, 2009, 11:18:15 pm »
I've sent a couple of emails, if you havent got them you can ring me on 0412747729 or send me yours, cheers John.
Re: yz250 a/b tank
« Reply #7 on: December 28, 2009, 11:26:28 pm »
John - is it a B tank your chasing?  If you dont want it then I will take it K2000x?
Rossco
Re: yz250 a/b tank
« Reply #8 on: December 28, 2009, 11:42:19 pm »
B's mighty fine Rossco
Re: yz250 a/b tank
« Reply #9 on: December 29, 2009, 12:39:04 am »
Ross or John, whats the Wisco part number for the YZ360 Piston ? need a 3nd over and cant find a number or even see them Listing one ?
OR are you using Yamaha MX 360A pistons ?
Re: yz250 a/b tank
« Reply #10 on: December 29, 2009, 01:06:09 am »
BUGGER!!!!!!!!!!!!!!!!!!!!!
Freaky - I don't have Wiseco numbers at all - sorry I am using OEM.
Re: yz250 a/b tank
« Reply #11 on: December 29, 2009, 12:10:51 pm »
Are you using the cut away or the window pistons ?
Re: yz250 a/b tank
« Reply #12 on: December 29, 2009, 02:44:59 pm »
if I remember rightly currently I have an MX windowed piston in mine but I don't have anything that far oversize?
Have those cables turned up yet Freaky?
thanks
Rossco
Re: yz250 a/b tank
« Reply #13 on: December 29, 2009, 11:09:05 pm »
oK so you have a 365 piston in it from a360A mx.
CAbles still over there, i got the feeling you werent that interestd, but they were the one you where after as it had the right end fitting as Davey crocket pointed out to me.  he also has genuine 431 sprockets too, but i think they were $50 or so, still cheap for what they are
Re: yz250 a/b tank
« Reply #14 on: December 30, 2009, 01:08:55 am »
Freaky - you wanker - what part of "yes please I will have a clutch cable" meant I wasn't interested????? ;D  Yes please but no hurry as I am not home until March.  Also how much effort does it take to make an MX tank fit the YZ?????
thanks
Rossco
