Marque Remarks
Suzuki
PE Barrel Swap
Topic: PE Barrel Swap (Read 2785 times)
suzuki27
PE Barrel Swap
December 13, 2009, 12:48:59 pm »
Can anyone tell me if the PE250T/X head & barrel will bolt onto an RM 250 T bottom end. Has anyone done it- or put the RM barrel onto the PE bottom end?. Thanks.
Re: PE Barrel Swap
December 13, 2009, 01:15:09 pm »
YES .....discussed at length some time ago. In my opinion they are the same.
Last Edit: December 13, 2009, 01:19:52 pm by oldfart
lukeb1961
PE175N, RM80B, JR50C
Re: PE Barrel Swap
December 13, 2009, 01:41:07 pm »
Yes, the same in all respects except for slight port height changes.
RM250T 11210-40302
PE250T 11210-40600
http://members.optusnet.com.au/pe175n
suzuki27
Re: PE Barrel Swap
December 13, 2009, 01:58:42 pm »
Thanks for that . Looking for some more bottom end power and thought I would give it a try- with the PE head as well.
LWC82PE
Superstar
Re: PE Barrel Swap
Reply #4 on:
December 13, 2009, 02:08:05 pm »
the RM250 T head is the exact same part number as the PE250 T/X/Z head. So you have nothing to gain by fitting a PE head on a RM.
Re: PE Barrel Swap
Reply #5 on:
December 13, 2009, 02:16:37 pm »
Power to be made in changing to Rm pipe along with Boysen reeds
Notice barrel on LHS has had some port work at some stage @ reed block & transfer
Marque Remarks
Suzuki
PE Barrel Swap
