Author Topic: What are these triple clamps?  (Read 3586 times)
« on: December 11, 2009, 10:18:47 pm »
They're a set of 35mm XL250 Motorsport forks in them, but they're definitely not Honda triples - something European.
And are they pre 75 legal?
What about pre-70 legal?
Offline matcho mick
    • Moto Tumbi
Re: What are these triple clamps?
« Reply #2 on: December 11, 2009, 10:47:39 pm »
 same as ossa super pioneer,no way pre 70, :(,maybe pre 75  :-\,clamping bolts/slots are angled back,early 70's betors triples bolts/slots are at rightangle to fork leg,Jim needs a set for his new tracker ;D, :P
« Reply #3 on: December 11, 2009, 10:58:17 pm »
They're Betor OSSA for sure. I'm using them on my pre 65 Hindall Ducati, pre '70 Cheney Yam and have had 'em on the DT1 from Hell since the 80's with no Nazi finger pointing. The DT1 ones came off a '70 ISDT Pioneer and the rest are identical and come off different OSSA models.
Great clamps because of the double pinch bolts and they polish up a treat.
« Last Edit: December 11, 2009, 10:59:48 pm by firko »
Offline oldyzman
  • 250 two stroke!
« Reply #4 on: December 11, 2009, 11:02:17 pm »
Gday Nathan, hope you are well. See the bolts with lock nuts on the fork caps, do you suppose they are to adj the spring preload? By the way thanks for that bit of friendly advice quite a few months back, when you told me just to do the race thing and not get too caught up with all of the formalities. Ive done four or five days at nepean at in the last 6 months and just had a great time.
Cheers Brett
Offline matcho mick
    • Moto Tumbi
« Reply #5 on: December 11, 2009, 11:09:13 pm »
good on ya Firko,i was bullshitting them down,so Nathan wouldn't want to use them,& Jim could,(that way i didn't have to give Jim my spare set, ::)), :P
Offline BJJ
    • Remote PC
« Reply #6 on: December 11, 2009, 11:15:24 pm »
yey!  I am so glad I guessed Ossa.  What a great week I have had.
« Reply #7 on: December 11, 2009, 11:17:37 pm »
nathan
i could use those tripples if you dont want them.
if so can you bring them with you as well
Oppet
« Reply #8 on: December 12, 2009, 08:28:01 am »
I have one of those allso, but I think they are from Can-am, not sure thou. mine has black betors on them, as you see...
If you have nice alu/magnesium conical hub that goes easy with these, Im intrested
Offline JC
« Reply #9 on: December 12, 2009, 10:24:29 am »
Oppet, those are definitely Canam forks from an MX3 125/175 or 77 Qualifier 175/250
Nathan, the triples are definitely Betor, either Ossa or Husky 125/175 if the offset is 56mm & distance between tubes is 135mm.
Bul & Canam betor triples are somewhat similar but Bul's had less offset (34mm) & Canam had wider forktubes (145mm)
