Author Topic: White power shock.  (Read 3056 times)
Offline D project
White power shock.
« on: December 01, 2009, 10:41:51 pm »
I have a white power shock to fit a rm 500, any one know how the bushing's come out?
They seem to have a shoulder on one side. Do they just press out?
Thanks.
Re: White power shock.
« Reply #1 on: December 01, 2009, 10:53:49 pm »
Im not sure if you mean the bushings in the eyes or the shaft bushing. If you mean the mount bearings then yeah the early ones have the bearing pressed into a adapter ring and you need to press out the adaptor ring first and then push the bearing out the adaptor.
Offline D project
« Reply #2 on: December 02, 2009, 08:54:46 pm »
Thanks, it  seems to have a rubber bearing which is pressed into the top shock mount and that has a sleeve
that the bolt goes through.
