Author Topic: SP370 carby, tank & seat  (Read 6097 times)
TT
« on: December 01, 2009, 10:39:09 pm »
Pretty self explanatory. I'm after a carb, tank and seat to fit an SP370. '78 or '79.
Doesn't have to be OEM carby and DR400 may even work?
Also after DR400 bash plate and the small rectangle headlights that came on the DR370. Maybe RS250 and DS80 may fit??.
pm, email or call me on 0410 504 815 if you have something for me.
Thank you.  :)
« Last Edit: December 01, 2009, 10:45:37 pm by Tony T »
Re: SP370 carby, tank & seat
« Reply #1 on: December 01, 2009, 11:25:22 pm »
i used to sell alot of std 34mm tt500 carbs to the sp boys and they worked well with a pipe and  opened up airbox,they bolt up easy being from the same family of mikuni range and you gain a 4mm increase in carb size
Offline fatboyracing
« Reply #2 on: December 02, 2009, 06:16:59 am »
Hi Tony,
That motor I gave you a while back now did you get the carby with it? and did it go I was told it was a good goer. Just very interested. If you didnt get the carby with it, it must be in my shede some where.
fatboy
« Reply #3 on: December 02, 2009, 06:55:39 am »
Bash plate and carb available , no seat
TT
« Reply #4 on: December 02, 2009, 07:42:45 am »
Thanks fatboy. No, there was no carby on that one. But you're right, I did pull that engine down and it all looked pretty reasonable in there.  ;D
pm sent oldfart. Thank you.
I've also had an email from a guy with a seat, so I've got nearly everything I need within 12 hours! Thanks fellas.
« Last Edit: December 02, 2009, 07:46:39 am by Tony T »
Offline EML
« Reply #5 on: December 02, 2009, 11:04:30 am »
What's the project Tony T?
I may have one of those DR headlight assys but I think it is cracked below the number plate.
TT
« Reply #6 on: December 02, 2009, 11:57:57 am »
Nothing too exciting EML. Just want to put together a DR370.
We didn't get them in Australia but most SP370 parts are the same.
The headlight I'm after doen't have a number plate. Like the photo below.
Offline EML
« Reply #7 on: December 02, 2009, 12:42:37 pm »
Arrh DS80 I think
Offline steve234
« Reply #8 on: December 02, 2009, 05:41:52 pm »
I am doing the same thing....
Have you any little tips i can use to make things easier etc? I haven't started yet but intend on a full engine rebuild, a few frame mods and some panel beating on the tin ware.
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
TT
« Reply #9 on: December 02, 2009, 06:02:49 pm »
Steve
Good stuff, Steve. I've had a few SP's and know them fairly well, but haven't gone down the path of modifying them much.
I've got parts and workshop manuals if you need anything out of them and a lot of spare engine parts.
oldfart is pretty clued up on modifying these things.
Keep us posted how you go with it.  ;D
Offline EML
« Reply #10 on: December 02, 2009, 06:31:09 pm »
Steve, I'm picking up the bits for my DR500 sidecar project tomorrow and the guy has some SP400 stuff. I will see what he is interested in parting with. I know he has one SP400 he is getting ready to use as a ride-to-work hack as I repaired the frame for him.
« Reply #11 on: December 02, 2009, 08:44:40 pm »
I have SP 400 frame looking for a NEW home before it makes land fill ......Free , yes free.
Offline jimson
  • Sanctuary point N.S.W
« Reply #12 on: December 02, 2009, 09:04:15 pm »
TonyT I've had a look through this blokes shed and seen a SP370 engine so he might have other bits Shoalhaven motorcycle Wreckers ph 02 4422 4537 jimson
TT
« Reply #13 on: December 02, 2009, 10:17:36 pm »
Thanks jimson
The only things I think I'm going to need now is a tank and a DS80 (?) headlight.
But I wouldn't say no to side covers and guards.
I'll give them a call tomorrow.
TT
« Reply #14 on: December 02, 2009, 10:38:50 pm »
Thanks to LWC, I have now tracked down a headlight.
Thanks all for the help.  :)
