Author Topic: DT1 cylinder head  (Read 4501 times)
Offline ji107
DT1 cylinder head
« on: November 23, 2009, 04:19:09 pm »
Does anyony know if there were DT1/2 cylinder heads available without the cut off fins on the RH side,to clear the pipe?
If they were available does anyone know where I can get one?
J I
Re: DT1 cylinder head
« Reply #1 on: November 23, 2009, 04:50:41 pm »
Not to my knowledge.
If you wanted fins for a particular project you could cut them off a spare head and weld them on ;). I've seen repaired fins and you would be hard placed to pick 'em 8).
Offline ji107
« Reply #2 on: November 23, 2009, 04:56:22 pm »
I may have to go that way, but would prefer not to.
How about RT1 head?
« Reply #3 on: November 23, 2009, 05:42:39 pm »
How about RT1 head?
Ditto.
« Reply #4 on: November 23, 2009, 07:59:34 pm »
DT2MX from memory. But I'm probably wrong. :-[
« Reply #5 on: November 23, 2009, 09:15:35 pm »
You mean all same height or only the very end ones ?
I have Dt1 heads that have both end fins same heights but are slightly lower in the center, 2 plugs also and run inline with the frame not at right angle like the normal DT1 heads you see.  I think the casting is 214 but id have to look, sorry no foto here, down at other place.
other similar options are YZa
or DT2mx
« Last Edit: November 23, 2009, 09:23:16 pm by Freakshow »
Offline ji107
« Reply #6 on: November 23, 2009, 10:48:57 pm »
Yes, like the one in the photo (no52), or similar
« Reply #8 on: November 30, 2009, 12:08:03 am »
Here is a webco i have, same all the way across.
This one not sure, its off the YZ but its sand cast so im not sure someone might be able to ID it???  The square sections seem to be part of it as there equal levels and not cut with a grinder or similar. I have no idea what it is, what does the ACK look like ?  anyone
also while on the subject them red alloy Bolts are they able to be torqued up to the same Lbs as the steel ones or safer to leave them a bit on the soft side ?
« Last Edit: November 30, 2009, 12:10:28 am by Freakshow »
