Marketplace
Wanted
VR Montesa rear axle.
Topic: VR Montesa rear axle. (Read 785 times)
November 21, 2009, 11:35:31 am »
I'm in need of a Montesa VR250 rear axle, nut and any spacers. I'm not certain of what other models are the same but I leave that to you Monty Knowalls
. Does the King Scorpian use the same conical rear hub?
Re: VR Montesa rear axle.
November 21, 2009, 11:55:27 am »
Quote from: firko on November 21, 2009, 11:35:31 am
Yes, and I'm 98% sure the axle is the same. The VB VE FE VG and H6 H7 use the same hub but longer axle (maybe 20-30mm). All use snail cams. I think they are 17mm and the same as a number of Yammies including MX DT etc.
Marketplace
Wanted
