Author Topic: HAS THE ELIGABILTY CHANGED FOR THE SQUARE BARRELL IN PRE 70  (Read 2193 times)
Offline paul
« on: November 18, 2009, 04:01:57 pm »
18.7.4 Tables of Machines and Components –
Pre 1970
18.7.4.1 Acceptable for the Pre-1970 class are
machines built up to and including the
1969 model. The only exception to
this GCR is where the model remains
unaltered after this date.
MAKE MODEL(S)
AJS Stormer (all)
BSA B44 up to & incl. B25, C15, Bantam
Bultaco
Up to & incl. MK4 boat tail Pursang &
El Bandido, Sherpas & their Enduro
versions (Lobito, Matador, Campera).
CZ Twin port, 360(969-0), 250(980-02)
DKW 5 speed
DOT Any
Greeves Any alloy beam model. All steel tubing
frame models numbers 56, 58, & 59
Honda CL175, CL350
Hodaka Ace 100, Ace 90
Husqvarna Any oval case engine in original frame
250, 360 & 400
Jawa Scrambler & banana frame 6 day bike,
Jawa early CZ 250 trail bike
Kawasaki F2IM(250), F4(250), F5(350)
Maico Oval case engine square barrel 250
& 360
Montesa Lacrosse 250, Orange Capra GP250,
GP360 & early King Scorpion
MZ ISDT
Ossa Stiletto 4 speed, 230 Pioneer 4 speed
Suzuki TS250 1969 model, points ignition &
appropriate engine cases
Offline paul
Re: HAS THE ELIGABILTY CHANGED FOR THE SQUARE BARRELL IN PRE 70
« Reply #1 on: November 18, 2009, 04:04:35 pm »
DOES THAT MEAN NO 400 SQUARIES
NO CONICAL FRONT HUB
NO REAR ALLOY HUBS
NO LATER CLUTCH OR IGNITION COVERS
NO ALLOY SWING ARMS
NO ALLOY BRAKE PEDALS
360S HAVE THE DECOMP AT THE FRONT OFF THE BARRELL SO THERE EASY TO ID
« Last Edit: November 18, 2009, 04:06:29 pm by paul »
« Reply #2 on: November 18, 2009, 04:26:20 pm »
Paul...Stop panicking. The square barrel Maico is legal in all of its forms. To make it all legit you need oval cases not the later sand cast cases. I've run my 350 with conical hubs including an alloy rear for 20 years but I've been told that it's not correct so will be changing them.. Use the full width hub, steel rear and all is well. Don't worry about the other shit, nobody's going to knock you back for having an alloy brake pedal. Alloy swingarms are ilegal even though I have proof of the Boyd and Stellings arm on my Maico being available in 1969. I'm removing mine not because I'm scared of being chucked out but because I'm using it on my Rickman Maico project.
If I'm wrong and 350 and 400 squaries are ilegal for pre '70, Peter Bowen, Laurie Alderton, Mark Firkin, Daryl Lewis, Mick Cady, Chris Ellis, Cary L'Estrange and possibly a few more should give their championship trophies back, publicly apologise and the scrutineers who passed them sacked for ever. All of the above and more have won trophies at National level open meets on 400 and 350 squaries and not a word has ever been said to them to my knowledge.
« Last Edit: November 18, 2009, 04:28:01 pm by firko »
Offline paul
« Reply #3 on: November 18, 2009, 04:41:12 pm »
NOT PANIKING JUST WAS READING THE REGS
211kawasaki
« Reply #4 on: November 18, 2009, 05:25:27 pm »
Calm down you guys. All is well in the square world of Maico.
Offline bazza
« Reply #5 on: November 20, 2009, 04:55:26 pm »
Got a square barrell, a b44 or any bike, choose a paddock and go race if your in Nzud if your in auz get the rule book and lawyer out......lol
Embrace patina
