Author Topic: As confusing as an alloy 125C swingarm?? Hope not  (Read 4504 times)
Offline SLAWESY
« on: November 16, 2009, 07:33:29 pm »
One relativley simple question. I know the answer would most likely be availabe on the forum somewhere however I am hoping that it may not be a confusing as the alloy RM swingarm question.
Q: Can you use (new) Ohlin shocks  with damping adjustments on the RM250T and still be ok in regard to eligibility for EVO class at the nationals? IE: Rebound and compression adjustment and piggy back
YZ125E, RM250T
Is it way too small? A bit of work with the heat gun or hot water could soften it enough to fit if it's close. Maybe some rubber friendly grease as well.
Mainline "classic"
Offline suzuki27
Re: As confusing as an alloy 125C swingarm?? Hope not
« Reply #1 on: November 16, 2009, 07:37:28 pm »
YES.
Offline SLAWESY
« Reply #2 on: November 16, 2009, 07:39:08 pm »
YES.
Shit that was easy..... Thanks suzuki27
YZ125E, RM250T
Mainline "classic"
« Reply #3 on: November 16, 2009, 07:48:37 pm »
It shouldn't be a problem using them but someone will probably disagree.
Offline SLAWESY
« Reply #4 on: November 16, 2009, 08:31:48 pm »
That's what i thought Johnny going on what I have seen in other threads.... ;D
YZ125E, RM250T
Mainline "classic"
« Reply #5 on: November 26, 2009, 11:39:19 pm »
SHock design is free only the travel restricted, and the use of cans to post 75.   You can run what you like, that can do what you like so long as the travel at the axle is in spec.
Offline Canam370
« Reply #6 on: November 27, 2009, 08:22:14 am »
correct me if I'm wrong (here we go.......) but isn't there a restriction on the overall length of the shockers to be no more than 'x'% over the specified original spec length? Or is this only in pre-75? :-\
« Reply #7 on: November 27, 2009, 11:24:27 am »
Thats a new one to me.  ONLY thing i have ever seen relating to dimentions and ratio;s in the MOMS is handlebars and layouts in Speedway, and also positions of sidecars and clearance, but never seen it for solo's relative to period  DT or MX
« Reply #8 on: November 27, 2009, 12:32:19 pm »
I think you're right Canam but only applies to pre '75. No more than 1" longer than std.
« Reply #9 on: December 04, 2009, 03:28:22 pm »
CAn you give me a page number  in the MOMS so i can look it up.
« Reply #10 on: December 04, 2009, 09:53:05 pm »
Their used to be something about shock lengths in the rules years ago but I think it has been removed.
There has been a few rules removed over the years. I often wonder if they were removed on purpose or just left out in some sort of "typo"
