Author Topic: Okay........  (Read 2403 times)
Okay........
« on: November 11, 2009, 07:34:53 am »
.......what have I missed ::). I've given this a few sharp blows with the trusty Tapometre but it didn't move a fraction. These are normally just a slip fit aren't they? (standard taper roller bearing in a 44M).
All Things 414
Re: Okay........
« Reply #1 on: November 11, 2009, 07:41:03 am »
Yup. It should just about fall out when you undo the nut.  :-\
Re: Okay........
« Reply #2 on: November 11, 2009, 07:45:22 am »
Okay, I'll implement the old Fitter and forker's motto; 'If you first don't succeed, get a bigger hammer' ;) ;D.
Offline caps 999
Re: Okay........
« Reply #3 on: November 11, 2009, 10:02:20 am »
mmmm rusty dam spanish bikes  ;)
MUGEN power
Offline mike1948
  • Margate, QLD
Re: Okay........
« Reply #4 on: November 11, 2009, 10:20:44 am »
I had an enduro model which all the heat in the world wouldn't budge.  I had to grind through the inner part of the bearing & split with a cold chisel to remove.  Other ones, no problem.
Mike
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: Okay........
« Reply #5 on: November 11, 2009, 10:32:02 am »
Sometimes you have to really pound on the stem!  Use a big block of wood and wail on that baby with a big hammer.
« Last Edit: November 11, 2009, 10:33:38 am by cappra »
Re: Okay........
« Reply #6 on: November 11, 2009, 11:25:35 am »
Thanks guys, it's out. I just needed reassurance. The one on the VB goes in and out effortlessly. I thought I was doing something wrong. I couldn't imagine it being a press fit but needed to check. I don't think it was a rust issue just a very close tolerance - just good Spanish engineering ;) ;D.
