Author Topic: whY WONT IT BUDGE AND WHAT THE HELL IS IT.  (Read 11087 times)
« on: November 02, 2009, 11:25:47 am »
Decided to look at Building this Pre 70 thing the other day and pulled out a 360 motor, Now 2 parts to this question.
After removing the head and then trying to lift barrel nothying happened, proceeded to try ever increasing blows with a drift and still no movement exept fo the 2 fins that broke off on the bottom.
Must only be stuck on the case surface, but i coulndt find the heat gun to try to excite it that way.
Now
Part A  - how the hell do i get the barrell of without doing any more damage.
Part B - motor has no serial numbers, but it wasnt till i had given up and put it back on the shelf next to another one that i noticed it was differant to the Other RT1, but please dont tell me i just beat the shit out of a rare RT2mx barrell, ( yes its on standard clean bore too  ::))
there are no casing on the barrel, no decomp and its not YZ cause its Piston port so whats left ?
any internal way to tell what the motor is ? clutch basket isnt YZ so im sticking to RT somting ..... ideas anyone.  NUmber area is blank and flat surface not ribbed.
« Last Edit: November 02, 2009, 11:33:24 am by Freakshow »
Re: whY WONT IT BUDGE AND WHAT THE HELL IS IT.
« Reply #1 on: November 02, 2009, 12:06:14 pm »
Part A. I would assume its corroded/stuck at the barrel/cases interface (I take it that the piston moves). Normally not two hard to break the bond here; the good old heat cycling, penerating oil and work it side to side (1-2mm) before trying to lift.
The fins are repairable/weld.
Part 2. If its RT2MX barrel its only the barrel; the cases look RT1. (I suppose you want me to check my RT1 barrel for markings ::) :P ;)).
« Reply #2 on: November 02, 2009, 12:21:15 pm »
a few cans of CRC which is fish oil based  8)
« Reply #3 on: November 02, 2009, 12:28:57 pm »
I had no marking except the 360cc stamp, the other rt1 barrell next to it has a casting number and also the vertical rods like the dt1 between the fins.
I guess im just dispointed it broke, instead of just tapping off.   YOu know hiow it ends up a 30 min job 2 hours later when you need to be somwhere else seems tyo always go to shit.
PArts. C regardless of what it is , if its piston port anyway does that mine its PRe 70 legal by definision of follow on anyway ? based on performance type not aethestics
« Reply #4 on: November 02, 2009, 12:31:41 pm »
Tried the fish oil down the studs and across the gasket but cant seem to get it to penetrate.  i think  i might have to bake and shake..........
Offline EML
« Reply #5 on: November 02, 2009, 12:39:11 pm »
Patients old Freaky, patients. Do you have some goanna oil-put that on it or put it in a drum of sump oil (not the best choice but usually plentiful) leave it for a few days/weeks/years. The knockometer is the last resort.
The Flying Flea is on hold 'til I can soak the barrel off.
« Reply #6 on: November 02, 2009, 01:30:15 pm »
Does the crank turn over & the piston move in the barrel?
You may find that it's all seized together.
You have missed a bolt.
« Reply #7 on: November 02, 2009, 03:59:39 pm »
Nope all bolts out they only have 4 down the guts.  And yep i can turn the flywheel and it goes up and down.
It can only be stuckon that crank surface.  MAybe the alloy case has done a bit of growing onto the steel liner.
I'll try the torch and spray it somemore ( or just put it back on the shelf for another day - i have scared it enough if it thinks its won it might just losen its own grip )
« Reply #8 on: November 02, 2009, 04:16:33 pm »
Offline jimson
  • Sanctuary point N.S.W
« Reply #9 on: November 02, 2009, 04:51:31 pm »
Freaky take the carbie off slide a piece of dowle down through to the exhaust port and slowly push the kick starter over with your hand.jimson
 Dowle maybe a piece of broom handle
Offline crs-and-rms
  • heaven 23
« Reply #10 on: November 02, 2009, 05:17:07 pm »
fill the crank case and bolt holes full of 3 parts kero and one part oil  till it runs out the exaust port and leave for a week then try we use to do this to free up lead cables that were in iron pipes back when i worked for the pmg
« Reply #11 on: November 02, 2009, 07:23:55 pm »
thats a clever idea Jimson, so the piston leverges the action huh, i like it.
knowing my luck its snap's off inside or bends somthing in there.   ::)
Offline frostype400
« Reply #12 on: November 02, 2009, 07:40:29 pm »
Freaky  I got a seized barrell off with brake fluid down the bore it took a while but I came back hours later and it had went past the piston and it slid off easily thanks, Michael.
1971 tm400 and PE's
Offline jimson
« Reply #13 on: November 02, 2009, 08:24:33 pm »
Freaky thats why you use wood it should give before anything else  ;D I would still lube the old girl up first. Before you put the broom handle in  :-[  :)  :D jimson
« Reply #14 on: November 02, 2009, 08:36:20 pm »
Frosty, you are on to it  ;)  brake fluid.
