Author Topic: Wanted KTM  (Read 10273 times)
oz555ktm
Wanted KTM
« on: July 31, 2007, 07:05:15 pm »
     Wanted
                   1984 or 85 125cc bike or Parts
                   also
                   Any 1980 125cc parts
Offline Barronvmx
Re: Wanted KTM
« Reply #1 on: August 19, 2007, 09:07:16 pm »
I have a 83 125 which is probably the fastest EVO 125 I've owned ofcoyrse its a Husqvarna not a Keep Taking your Money.
Huskies
CR250 1972, CR400 1972, SC125 1973, CR250 1975GP, WR250 1979/80, XC125 1983, TX510 1983, XC125 1984 project, CR250 1984 project
Honda's
SL100 1971, XL100 1974, Hondasaki 210, XL185 1981 project
Jawa's
1959 250 project, 1969 175 trail boss project.
Sachs 1969 125
Offline Fenno
Re: Wanted KTM
« Reply #2 on: September 12, 2007, 09:26:59 am »
dennis I thought that you arent allowed any more bikes
Anyway what regulations do I need to stick to for the pre 85 class
can I add later model bike parts to my pre 85 such as late 80's brakes
do I need a front sproket cover on my 83
CR480rd
CR250rd
plus years of collecting 83 Cr junk
Re: Wanted KTM
« Reply #3 on: September 12, 2007, 08:53:17 pm »
Yes you need a sprocket cover. Doesn't have to be the original one, just something to stop fingers getting caught.
No you can't fit post-85 bits legally. Because the pre-85 class isn't defined in the manual (yet), the exact rules depend on the club running the event.
Generally speaking, everyone looks at the VMX regs that are in the manual (pre-75, pre-78 etc) and converts them to suit the pre-85 bikes. This means that shocks, ignitions, controls (levers, bars etc), pipe/muffler, engine internals and cosmetics are free, but everything else needs to be made before 1985, or be indentical to bits made before 1985.
In reality, minor transgressions are usually over-looked. Unless you're particularly fast and/or obnoxious you'd be unlucky to get pulled up on having an 85 motor in your 83 bike (for example).
Re: Wanted KTM
« Reply #4 on: September 17, 2007, 04:17:28 pm »
as i understand it, don't need a sprocket cover if distance from nearest tooth to frame is less than......some distance.  i think 30ml.  but most 80s plus bikes don't need them cause they needed to locate cogs near as poss to frame to keep the chain on all thru susp travel.  i'd be sure your rd (like my rd) don't have to have one.
Offline maicomc490t
Re: Wanted KTM
« Reply #5 on: November 20, 2007, 10:49:29 pm »
The GCR's (or competion manual or whatever the hell it's called these days) spells out the specs for maximum clearance and whether a chain guard is required. Don't get tangled up in the additional requirements for PRIMARY drive covers though.
If you are going to tough it out and not run a chain guard make sure the law is on your side - you could drive a bloody long way only to be a flaggie !!!
See you at the back of the pack in 08  ;)
BULTACO M49 parts wanted
oz555ktm
Re: Wanted KTM
« Reply #6 on: December 01, 2007, 12:21:58 am »
I am Still Looking for a 1984 125cc KTM
Will Swap or Cash .
oz555ktm
Re: Wanted KTM
« Reply #7 on: December 22, 2007, 12:29:54 pm »
              Wanted KTMs From 1973 to 1985
              125cc , 250cc or Bigger .
              Parts of Bikes
oz555ktm
Re: Wanted KTM
« Reply #8 on: April 10, 2008, 10:28:27 pm »
I am Looking for a 1975 to 1977 250cc engine cases or Bottom
end or a motor or Parts bike .
0411 598 818
090
Re: Wanted KTM
« Reply #9 on: May 05, 2008, 08:59:25 am »
If you are still after an '84 125 i have one. Has alot of spares with it. I want the $1000 i paid.
Offline T250K
Re: Wanted KTM
« Reply #10 on: May 05, 2008, 10:33:13 am »
Oz555,  PM about 250 cases sent this morning.  Cheers,   Mike.
Offline T250K
Re: Wanted KTM
« Reply #11 on: May 07, 2008, 08:06:34 pm »
 PM sent this evening.   Cheers, T250.
Offline Oldmxnut
Re: Wanted KTM
« Reply #12 on: May 15, 2008, 10:10:50 pm »
I have a set of 40mm marzocchi forks and tripple clamps that came off a 82 mx 250 i think?   Very clean, with a few small spots on chrome, but not worth re-chroming for.
