Author Topic: cz head stem bearing  (Read 6351 times)
Offline HL400
« on: November 01, 2009, 03:25:26 pm »
Hi all does any one know the bearing number of the tapered roller bearing for a cz head stem. ??  HL
Re: cz head stem bearing
« Reply #1 on: November 01, 2009, 04:12:02 pm »
no
mine has not got tapered bearings.you can buy kits from C.R. in the usa
Ji Gantor
« Reply #2 on: November 01, 2009, 04:39:45 pm »
Hi HL,
The steering head bearings had loose balls.
CR has tapered roller bearings for sale.
I have a pair and they work great.
The kit is not just the bearings.
There is a pressed in lathed centre to make up the difference.
I suggest you buy them from CR as I could not even find the bearings as they are a really strange size.
Ji
Offline HL400
« Reply #3 on: November 01, 2009, 08:15:40 pm »
Thanks Ji, I thought that would be the case.  Better send him another Email. O well at least the $ is high.
 HL
Ji Gantor
« Reply #4 on: November 01, 2009, 10:50:13 pm »
CR is a brother.
He is still getting over his near death experiance.
This man is worth being patient for.
His products are the very best.
I spent about a week searching for the bearings without success. I don't know where he gets them from but I am happy he found them.
Ji
« Reply #5 on: June 16, 2010, 08:55:52 pm »
Bearing size is 48x30x13 which I found on wemoto, haven't found the seals yet
shakeyCZ
« Reply #6 on: August 30, 2010, 06:13:21 pm »
How did you go with the seal? you find one yet, as I found all my wheel bearings total of $75 aus dollars and seals, what size seal are you after?
« Reply #7 on: August 30, 2010, 06:38:44 pm »
No luck with the seal, it's the same as the bearing etc as the lower 1 from an all balls set for a lot of yamahas including my ty.
OD 49
ID 40 of seal
ID 32 of steel base plate
Not sure if they dimensions help but here is the lower bearing numbers off the all balls bearing
Inner race KML brand  30YMI-G8YI  possibly a C instead of G.  This is where seal locates to
Outer race has same code
Would be nice to know if something else runs these bearings standard instead of an upgrade from loose balls
shakeyCZ
« Reply #8 on: September 14, 2010, 11:57:33 am »
Hi HL,
Ji
Hey you wouldnt no what part number was on the seals that you would have got with the bearing kit? i have the spacer being made to make up the difference. any help would be good :-\
shakeyCZ
« Reply #9 on: November 23, 2010, 12:39:17 pm »
well this is the seal you need i found it here i save around $50 sourcing it my self bearings and seals  http://simplybearings.co.uk/shop/Taper+Roller+Bearings/c1/p43736/Washer+to+fit+32005X+&+32005X/26+Narrow+Section+Steering+Head+Set+Taper+Roller+Bearing/product_info.html
it fit perfect but its a shame you have to get the bearings from wemoto  http://www.wemoto.com/parts/picture/HL-324808/
but if you follow the links you should have no problems just you will have to get a spacer made up, i was lucky I have a flatbed CNC so I made my own and pressed them in.
 good luck any way hope this helps some one out
