Author Topic: CR125/250/480/500 rear springs  (Read 2154 times)
Offline motomaniac
« on: October 29, 2009, 09:15:20 am »
2 unused rear shock springs from original spareskit forsale.
suit 81/82/83/84   . they have been calibrated and are 7.35kg and 5.05 kg
the 7.35 might be good for someone with an 83 who needs heavier than the optional 6.4kg
the 5.05 would be good for a 84 - heavier than the standard 4.5 or optional 4.8
$70 each pickup melb or plus COD .I dont do regular postage .
PM if interested.
« Last Edit: November 11, 2009, 01:41:17 pm by motomaniac »
Re: CR125/250/480/500 rear springs
« Reply #1 on: October 29, 2009, 07:29:20 pm »
whats standard on an 83 250?
Rossco
090
« Reply #2 on: October 29, 2009, 07:46:30 pm »
Isn't the 84 a smaller spring?
I'm interested in a heavier spring for my 83 480. Will it definitely fit that?
Offline motomaniac
« Reply #3 on: October 29, 2009, 08:27:40 pm »
Rossco
standard is 6.0 kg . heavy is 6.4kg. --- 7.3kg might be too much but depends on your weight
Offline motomaniac
« Reply #4 on: October 29, 2009, 08:43:08 pm »
I can measure then up to make certain Brad , I wouldn't want to be wrong but I have 82/83/84 /85/86 shocks here the 82/83/84 are all 40 mm bore and a small ID spring .85 on had 44mm bore and a bigger ID spring the and later again came 46mm and 50mm for moderns.
the 7.3 is probably too big a step for your weight Brad .
okay measured 265-270mm long and 56mm ID
I also have a FOX twin clicker with a 6.2 kg spring for 83's. Its missing the bump stop and the spring retainer(easy make ,aluminium copy, Capps has the Dimensions)probably needs seals but chrome is good.
090
« Reply #5 on: October 29, 2009, 08:46:52 pm »
Is the Fox for sale? If so how much?
« Reply #6 on: October 29, 2009, 09:41:59 pm »
I don't weigh much but my gear is really heavy!!!!!
Rossco
Offline motomaniac
« Reply #7 on: November 11, 2009, 01:43:03 pm »
The 7.35 kg spring is sold .
