Author Topic: 36 mm disc front end  (Read 3221 times)
Offline frostype400
« on: October 27, 2009, 05:05:44 pm »
I am after a front end to put on one of my pe400's. I want to keep the original trees and headlight but I'd really like a front disc if i could get some 36mm front forks etc etc with a front wheel etc etc. I am not to fussed what sort they are but just need to be 36mm please pm if you have something. Also chasing some 400mm or close to 400mm gas shocks piggy back or anything will do rebuilding isnt a prob either just trying to put together a good bike with a project pe400 I picked up thanks alot Michael. :)
« Last Edit: October 27, 2009, 05:08:16 pm by frostype400 »
1971 tm400 and PE's
Offline mick25
  • Hunter valley NSW
Re: 36 mm disc front end
« Reply #1 on: October 27, 2009, 06:30:34 pm »
I havent got a disc front end for you , but i put an xt 250 disc front end on a xt500 they were a couple of inches longer than org and were 36mm.
they would suit the pe,this may help or not
« Reply #2 on: October 27, 2009, 06:33:12 pm »
1985 to about 88/89 Enduro model DR 250 has 36mm disc front end but i doubt the forks are long enough for PE
XT350 from 86 onwards has 36mm with disc. i would look at that. go to bike pics website to find pics of XT350.
Offline frostype400
« Reply #3 on: October 27, 2009, 07:02:12 pm »
ok anything would be good i spose it wouldnt matter if it was a little more and just have to slide a bit extra through the trees better a fraction longer then to short i spose i create a problem with the rear if the front gets jacked up i cant really change for much longer shocks on the rear thanks for the advice guys
1971 tm400 and PE's
« Reply #4 on: October 27, 2009, 07:10:30 pm »
KLR 250 85 onwards also has 36mm disc. Legs might be a little too short though. Plenty of those at wreckers and in just bikes.
also maybe look at some late 80's to early 90's 80cc mxers. They have long forks and some are 36 i reckon. You would need stiffer springs though or the PE ones might fit in
Offline frostype400
« Reply #5 on: October 27, 2009, 07:14:32 pm »
hmm was thinking it would be really easy to do i definetly want to do it to this pe400 roller i have but sounds like i need to do some research i seen one on ebay not long ago with drz front forks but i wonder how much work went into that surely something should be within fairly close length and 36mm ??? i rang a wreckers and he suggested klr250 but i dont think was sure on length i dont mind paying a bit extra for something that just slides straight on thanks Michael. :)
1971 tm400 and PE's
« Reply #6 on: October 27, 2009, 08:02:50 pm »
i put a drz250 complete front end on my 1979 it/yz400.i first checked to see that bike had the same size bearings and went from there.a little bit of machineing here and there.bolted right in.this is the best way as you then dont have to make brackes ans spaces to mount the brake calaper and wheel with disk.
jim
Offline frostype400
« Reply #7 on: October 27, 2009, 08:14:18 pm »
yeah thats what i wanted to do i will keep my originals but it would be great if i find a complete 36mm disc front end to slide straight in to the pe trees
1971 tm400 and PE's
« Reply #8 on: October 27, 2009, 08:23:15 pm »
I have  KLR front end but not sure i can get to at the moment. I will have a look. i know they have about 220 or 230mm travel and teh PE has about 250. when i thought of doing i was going to use a DR200 or 250 wheel as they are 12mm axle so fit right in and then fabricate my own bolt on caliper mount like on Steven Galls YZ490 when he fitted a XT600 front disc wheel around 83/84 and had a clamp on caliper holder. Ive got pictures of that bike somewhere. other option is to get another PE outer fork slider and weld mounts to it if you want to keep the original set unmodified. Theres plenty of PE forks out there.
Offline frostype400
« Reply #9 on: October 27, 2009, 08:57:38 pm »
 thanks Leith if that klr fornt end could work it would be great thanks alot Michael. :)
1971 tm400 and PE's
« Reply #10 on: October 27, 2009, 09:13:07 pm »
klr250 disc brake wasnt much better than a good tls drummy and klr's suspension could be compered to a wet sponge,what about xr250 honda's they have twin piston calipers
« Reply #11 on: October 27, 2009, 09:24:59 pm »
frosty its not for sale sorry.
Offline frostype400
« Reply #12 on: October 27, 2009, 09:43:47 pm »
i know where one is $350 is that good
1971 tm400 and PE's
