Author Topic: whats a 81 450 bottom end worth  (Read 1645 times)
Offline Fenno
« on: October 27, 2009, 03:55:04 pm »
Hi
 while most of you are talking about the 81 cr's
Whats a really good bottom end worth for a 81 450, all it needs is a top end and its a goer
CR480rd
CR250rd
plus years of collecting 83 Cr junk
Offline Marc.com
Re: whats a 81 450 bottom end worth
« Reply #1 on: October 27, 2009, 05:02:05 pm »
I don't know may $200-$400...... a lot depends on who needs the cash at the time.... offer $100 and a carton.
Offline caps 999
« Reply #2 on: October 27, 2009, 06:06:00 pm »
ill give you 200 cash  ;D
MUGEN power
Offline Marc.com
« Reply #3 on: October 27, 2009, 06:22:32 pm »
Mostly good bottom end means you normally would strip and check it....then paint and reassemble, usually you can find head and barrel for $200-300, assuming it is all in good order add piston, then rod kit is advisable.... realistically you drop a grand into most motors if you start with good bits. A lot more if it needs specialist odd sized or doweled bearings etc
