Author Topic: Mk 11 Starting problems  (Read 1765 times)
jeffc246
« on: October 25, 2009, 09:45:32 pm »
I have just finished restoring my MK 11 and got it running after a couple of kicks " great "
Turned it off to put on some riding gear and now it wont start.
Checked spark and fuel, all good, reset timing as i have a Femso ignition set up from am old pursang i once had. cleaned out carbie, put in new fuel and still no go,
any ideas ?
Jeff
Offline David Lahey
Re: Mk 11 Starting problems
« Reply #1 on: October 26, 2009, 12:02:26 pm »
Maybe sheared the flywheel key as it stopped - now timing way out?
previous pseudonym feetupfun
« Reply #2 on: October 26, 2009, 12:44:30 pm »
if you sheard the key make sure you lap the flywheel on with fine valve grinding paste.the keyway is only there to get the timing right the 2 tapers must hold the flywheel on
