Author Topic: ts125 parts  (Read 1272 times)
kkj2009kkj2009
ts125 parts
« on: October 24, 2009, 08:25:05 pm »
i have a ts125 mid 70's
i am in need of an oil injector pump and lines, cover.
air box
tail pipe
rh side cover
may consider other parts
thanks
kkj2009kkj2009
Re: ts125 parts
« Reply #1 on: October 25, 2009, 02:11:47 pm »
bike is a 78 model
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: ts125 parts
« Reply #2 on: October 25, 2009, 05:38:16 pm »
I have an excellent muffler, but you will have to check the outside diameter of your exhaust pipe (if it's 22.5mm) to make sure it fits.
The muffler is from a TF125 which is the same as the pre "ER" TS125's like yours.  $20.00 plus postage
Side covers are real easy to get from Thailand as that is where most of Suzuki's surplus parts ended up.
Pick a colour
http://cgi.ebay.com/ebaymotors/SUZUKI-DS100-TS100-TS125-FRAME-COVER-BLUE-1PAIR_W0QQcmdZViewItemQQhashZitem1e53f845c7QQitemZ130257798599QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/SUZUKI-DS100-TS100-TS125-FRAME-COVER-YELLOW-1PAIR_W0QQcmdZViewItemQQhashZitem1e53f843e9QQitemZ130257798121QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/SUZUKI-DS100-TS100-TS125-FRAME-COVER-RED-1PAIR_W0QQcmdZViewItemQQhashZitem20a8bd5af7QQitemZ140269935351QQptZMotorcyclesQ5fPartsQ5fAccessories
After doing a little detective work on your oil pump problem I have discovered that the later TS125's (like yours) can run without a pump because the relief hole is there to allow intake oil (from premix) to pass through the magneto side bearing. but if you want the pump and cover here they are...
http://cgi.ebay.com/ebaymotors/78-81-SUZUKI-TS100-TS125-TS-100-125-VERY-GOOD-OIL-PUMP_W0QQcmdZViewItemQQhashZitem562f117021QQitemZ370156859425QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Suzuki-TS100-TS125-C-N-Oil-Pump-Inspection-Cap-Nos_W0QQcmdZViewItemQQhashZitem53d3d7a8faQQitemZ360036411642QQptZMotorcyclesQ5fPartsQ5fAccessories
If you want the muffler send me a P.M.
« Last Edit: October 25, 2009, 05:40:44 pm by cyclegod »
Ban BLACK rims NOW
