Author Topic: 465 muffler info needed  (Read 7911 times)
« on: October 21, 2009, 09:35:16 am »
Hi Guys, due to recent feedback it seems my 465 muffler jig is NQR.
I have what I beleive is a good jig for the 83 490 muffler, so does anyone know if this muffler is interchangable with the 465's
From what I can gather, the muffler that I jigged from for the 465 was not an original & must not have been fitting properly so I jigged a perfect replica of an ill fitting muffler  :(
If the 465 muffler is different to the 490 muffler then does anyone have a good fitting 465 muffler that I could borrow? Would only need it for a day or 2.
Offline Viper666
    • Ballarat Rovers MCC
Re: 465 muffler info needed
« Reply #1 on: October 21, 2009, 11:28:58 am »
They are different part numbers for both 82, & 83 but the 80 & 81 465 are the same.
I am about to restore a 465H for a mate for next season and maybe he will lend it but if I know him he will want something in return?
I will ask him.
Viper666
« Reply #2 on: October 21, 2009, 02:26:05 pm »
Thanks Viper, yes your right about the part No's, but it may be something as simple as the later muffler being 10mm longer that would bring out a new part No, so it doesn't completely rule out interchanging mufflers.
Depends how many arms & legs your mate wants.
Offline Viper666
« Reply #3 on: October 21, 2009, 05:27:10 pm »
He wants to keep the original pipe and mufler for when he retires the bike. He has a DG pipe already but doesnt have a mufler. What sort of deal could you do?
Viper666
Offline YZ250H
  • Back in QLD Baby !
« Reply #4 on: October 21, 2009, 07:31:42 pm »
Did you need the muffler or just some dimensions Geoff.  Not sure about the one I took off my bike, but it seemed to fit the bike OK.   You are welcome to have it if it is any good to you.  I will take some photos on the week-end if I get a chance.  I put a DG muffler on it in its place, but it does not overlap the standard pipe and needed a joint.  Are you after any particular measurements ?
If it helps the 250 and 465 frames are the same.
Offline holeshot buddy
  • sunshine coast qld
« Reply #5 on: October 21, 2009, 09:16:35 pm »
pretty sure 490j and 465h
dg pipe and mufflers the same dimensions ;)
muffler mount may vary :-\
follow me to first turn
yz490rules
« Reply #6 on: October 21, 2009, 10:08:39 pm »
The J muffler is longer than than the 465.  The J muffler has a resonater chamber on the muffler so the pipe is slightly shorter and the muffler tail longer.
Stephen
« Reply #7 on: October 22, 2009, 08:39:44 am »
Thanks for the input guys.
Dimensions aren't really helpful as angles & stuff is hard to define.
Ideally I need to borrow a good original. (Stuffed core doesn't matter)
The one I originall jigged from didn't have the front mounting bracket which leads me now to suspect it wasn't an origianl 465 muffler.
I need to set up properly the entry angle of the stinger tube & it's relationship to the mounting brackets
Offline torm92
« Reply #8 on: October 22, 2009, 08:40:52 pm »
I have a NOS 490 J muffler in wrapping if thats any good .
Restoring YZ 50,60, 80, 100 and 125. Racing a 490 and a 250. Have a complete collection of J,s.
« Reply #9 on: October 23, 2009, 08:48:13 am »
Hi Torm
Whereabouts are you?
It would be intersting to compare to my 83 K jig as the J & K models have differnt part No's for the muffler.
Offline torm92
« Reply #10 on: October 24, 2009, 09:45:59 pm »
Hi GMC , im in Doncaster but work in Campbellfield . Been wanting to get up your way to give you some work I need doing . Will I bring the muffler too?
Offline E74
« Reply #11 on: October 24, 2009, 10:21:51 pm »
I have an original 465H one here, PM me your address and I will send it down, just send it back when you are finnished
Offline YZ250H
« Reply #12 on: October 26, 2009, 06:17:04 pm »
There you go - once again very generous Darren.
I would have sent mine GMC, but I couldn't put my hand on my heart and say it was the right one.
« Reply #13 on: October 27, 2009, 06:23:49 pm »
Thanks Torm. Theres no urgency for the J - K comparison but it would be good to add to my knowledge base, so whenever you wander up this way would be fine.
Offline frostype400
« Reply #14 on: October 27, 2009, 07:10:54 pm »
do you do a pe400 one gmc i can lend a good one of those
1971 tm400 and PE's
