Author Topic: Idleling problem  (Read 1884 times)
lc4
Idleling problem
« on: October 20, 2009, 12:31:42 pm »
Have a Honda 50 (4 stroke) and cannot get it to idle in that you can set the idle screw at a certain rpm blip the throttle and it will slowly run down and stall. Have set air mixture at a happy medium (about 1 1/2 turns out from closed)  have fitted a new OEM carby,have set valve clearances,has new plug and strong spark (new points fitted). Any suggestions?
« Last Edit: October 20, 2009, 12:33:56 pm by lc4 »
monaro308
Re: Idleling problem
« Reply #1 on: October 20, 2009, 09:16:54 pm »
I can't remember if the 50 has the points at the engine flywheel or running off the cam....i'm just going off my SL70 from 30 years ago  :D  :D  :D
Check timing with a timing light.
Could have sticky or loose counter weight/springs causing strange idle problems.
Also try removing the air cleaner and with your hand,slowly block off the back of the carby....if the revs rise,you have a lean problem with either manifold leaks,carb jetting/adjustment or burnt out valve/s
You can also try with the choke on and see if it runs better or worse.
Just a few things for you to check.....cheers.
lc4
« Reply #2 on: October 20, 2009, 09:34:40 pm »
Thanks for the input monaro308
Points are located behind the flywheel and only offer gap setting other than cam timming which is spot on. Valves are 100% and all new gaskets on the inlet side, I will try your other trick and see what happens ;)
