KTM
can some one id these numbers
Topic: can some one id these numbers (Read 2557 times)
paul
October 19, 2009, 10:14:14 am »
frame 010122091
and engine is is either 0_04108801
or 54130004000
Moto
A-Grade
Re: can some one id these numbers
October 19, 2009, 07:31:04 pm »
Paul,
Frame stamped 0 =1980 and 10 = the month. October 80, which usually means an 81 model by the time it arrived here.Production for the next years model usually started in September/October
541 is a 250 (1981) usually enduro.
paul
October 19, 2009, 07:55:59 pm »
thanks moto .just one more? 541 is a endeuro for sure or can it be a mx. ok another how many speed gears box? for mx or endeuro
Last Edit: October 19, 2009, 07:58:22 pm by paul
bigk
Kangaroo Flat Victoria
October 19, 2009, 08:14:47 pm »
I'm led to believe, although it may well NOT be so, that they all had the six speed box, but the MX version had one gear blocked from selecting. Can anyone confirm this?
k
oz555ktm
October 19, 2009, 09:23:46 pm »
The 540 engine it is true that !st gear was Bolcked Out .
But by the 541 engine first gear was removed and had a Coller fitted ..
Best way to tell if a MX or Gs a GS has a Center stand ?? or will have the mounting brakets for it ..
Mx has a Floating back brake But so did sume GS
Gs have a Choke in the Carby slide ..and a Leaver on the Handle bars .
I could go on ..
A lot of KTM that came to Oz wear a Cross of the two a Gs with a lot of MX stuff like a XC
KTM
