Author Topic: PE 250 T/X chamber  (Read 2319 times)
Offline suzuki27
PE 250 T/X chamber
« on: October 18, 2009, 07:29:36 pm »
I am after a PE 250 T/X pipe. I have a nice RM 250 T pipe or cash to trade or buy.
Re: PE 250 T/X chamber
« Reply #1 on: October 19, 2009, 08:05:42 am »
Pipe's are of  same design, Pe has a bit of mesh welded internaly.
What sort of coin are you asking for RM pipe
« Last Edit: October 20, 2009, 06:48:13 am by oldfart »
Offline suzuki27
« Reply #2 on: October 19, 2009, 06:04:27 pm »
For the moment, I am wanting to swap.
The PE pipe I cut, 78 or 79 from memory, had 2 solid metal(tin) plates  spot welded in the fat part of the pipe- each with one smaller opening in the middle. About 2-3 fingers thick with the verniers.
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #3 on: October 19, 2009, 10:27:23 pm »
that would have been the C pipe or perhaps an N.
The C definately had the restrictors to quieten things down.
If you have an early PE, this definately was a sound and performance killer.
The T and later did not have that, but did have a wire-mesh lining the chamber to stop the drumming / racket that the RM pipe would generate.
