Author Topic: Gaskets  (Read 2373 times)
Offline AJ
Gaskets
« on: October 16, 2009, 10:47:30 pm »
I am having no luck getting a gasket kit for my '83Cagiva WMX 250 ( 190cc).
The bloke rebuilding the engine mentioned 20 thou green paper being required if I can't get a kit.
Can anyone assist with a source for kits?
Comments regarding the "green" paprer?
thanks,
AJ
Re: Gaskets
« Reply #1 on: October 16, 2009, 11:27:59 pm »
these guys appear to do before and after - are any of them similar - sorry if you have already been here.
http://motorcycleproducts.co.uk/catalogue/cagiva-full-gasket-sets-c-222_309_511.html?page=2&sort=2a
Also saw some on www.venhill.co.uk
Hope that helps.
regards
Rossco
Re: Gaskets
« Reply #2 on: October 16, 2009, 11:47:09 pm »
There is no need for this 'special green' gasket paper. A company called James A Walker has paper called Sentinel(even green coloured if you like), you can buy off cuts pretty cheap. A set of Super Shite auto wad punches your kept in gaskets for life. Gaskets are without a doubt the single biggest rip off perpetuated on hapless consumers.
AJ if your having trouble you can send the old gasket to me or a rubbing of the cylinder base and I'll make you one for nothing. Is that cheap enough?
Offline AJ
Re: Gaskets
« Reply #3 on: October 18, 2009, 08:31:47 pm »
Thanks for the advice guys.
Very generous of you Lozza.
regards,
AJ
