Suzuki
Expansion chamber repairs
Topic: Expansion chamber repairs (Read 6794 times)
October 15, 2009, 08:35:53 pm »
Rm 250 1980 chamber that required a new header pipe , white mark on pipe indicates reference point
Re: Expansion chamber repairs
October 15, 2009, 08:41:48 pm »
This image indicates materials reqiured Musket header pipe ( bought off flea bay for $20-00)
2 inch mandrel 180 u bend $26-00
First cut is to allow new header to slide up over chamber and show true cut line -
October 15, 2009, 08:47:46 pm »
Cut new header at dodgey weld ( 90 degree bend that enters head ) clean up new header with die-grinder ( piece in vice ) internal bore - cut 2 " mandrel bend in half and shorten long leg, cut off piece near my grubby thumb as you will require this at head manifold
Last Edit: October 15, 2009, 08:50:18 pm by oldfart
October 15, 2009, 08:59:29 pm »
trim your mandrel bend and shape it to suit entry at head , and add manifold section which is welded to 90 degree bend
Tack it all together and remove from bike making sure it can be re-installed with ease
October 15, 2009, 09:05:35 pm »
End result .....spring lugs are fence wire ( # 8 wire ) bent into shape
I have made the pipe fit closer to down tube , as front guards tend to bend and burn on pipe
materials just under $50-00 labour 4 hours over 3 nights
Time to post this thread 1 hour
Last Edit: October 15, 2009, 09:10:04 pm by oldfart
Lozza
October 15, 2009, 09:14:34 pm »
That turned out pretty good Stew
Rossvickicampbell
October 15, 2009, 09:27:58 pm »
actually very good indeed!
Rossco
pmc57
A-Grade
Reply #7 on:
October 15, 2009, 09:55:22 pm »
Stew
I thought I recognised that Musket header pipe and the barrel and head finish, then I saw who was the author of the thread and put tow and two together.
Great job Stew, I know where to come for any pipe repair work from now on.
pmc57
Reply #8 on:
October 15, 2009, 10:05:55 pm »
product replacement range .... they do sell to public ( MS 143 used ) as donour
http://www.musket.co.nz/product.asp?brand_id=1&cate_id=2&Submit2=Search&make_id=11&parttype_id=&model=&partNo=&offset=10
Last Edit: October 15, 2009, 10:07:35 pm by oldfart
DR
Reply #9 on:
October 15, 2009, 11:07:21 pm »
Well.. Well.. Well.. and what do we have here eh Stew
you saw Roger's TS185 with the Plankman header repair and you just had to go 1 better didn't ya!
problem is, your's still looks like the stock pipe
bazza
Reply #10 on:
October 17, 2009, 03:09:06 pm »
Stu you old duck shooter,nice job.You cant take the Kiwi out of the boy,only a kiwi would use #8 fencing wire
BJJ
A-Grade
Reply #11 on:
October 17, 2009, 03:11:09 pm »
Excellent addition to this forum. Thanks for posting!
http://stores.ebay.com.au/Remote-PC-for-Premium-Electronics?_rdc=1
http://www.fxbikes.com
http://www.mysoundracer.com
http://www.tvbgone.net.au
http://www.bokashi.com.au
Suzuki
