Author Topic: I D THIS NUMBER  (Read 2870 times)
BONEHEAD
I D THIS NUMBER
« on: October 15, 2009, 07:49:33 pm »
guys just wondering if someone coul ID this engine number please KX250AE004860, your help is much appreciated.  ;D
BONEHEAD
Re: I D THIS NUMBER
« Reply #1 on: October 18, 2009, 08:47:24 pm »
so could someone tell me where to find kx engine number or kawasaki engine number de coding.
Re: I D THIS NUMBER
« Reply #2 on: October 18, 2009, 09:06:54 pm »
Is it air or watercooled?
I think kawasaki use the same system as yamaha, honda and ktm, which is the 10th number in the sequence is year of manufacture.
Offline Trent Farlow
Re: I D THIS NUMBER
« Reply #3 on: October 19, 2009, 11:38:14 pm »
It is probably a 1980 KX250 Unitrak engine. The number is consistent with the A series of engines which ran from 1978 to 1982. There were about 1500 1978 models made, and about 2500 1979 models. Therefore it is right on the border between 1979 and 1980. It is easy to tell the difference - the 1980 model has the clutch actuator behind the cylinder on top of the cases, the 1978 and 1979 models have the clutch actuator on the clutch side of the engine near the front of the clutch cover.  Also the 1980 has a single large mounting lug at the rear of the cases where the swingarm bolt went through, the 1979 used a cradle which linked to the swingarm. If you post a few photos I will be able to tell you straight away as the motors look quite different.  Cheers.
kaw440
Re: I D THIS NUMBER
« Reply #4 on: October 20, 2009, 08:54:46 am »
79 KX250 engine number starts  kx250ae001801 goes to kx250ae010800 at the end of 1981 1982 starts at kx250ae010801 hope this helps
BONEHEAD
Re: I D THIS NUMBER
« Reply #5 on: October 21, 2009, 09:36:46 pm »
thanks guys , yep its a 79 kx 250 a5 1979, just trying to sought out a part i purchased from regulators and rectifiers in the states, its wrong and they wanted to make sure of its year modle . cheers  ;D
