Author Topic: DT400 TWIN SHOCK REAR WHEEL & CARBIE  (Read 2532 times)
Offline jimson
  • Sanctuary point N.S.W
« on: October 13, 2009, 07:07:02 pm »
G'day viewers I'm after a rear wheel in good condition for a DT400 twin shock the part number in the hub should be 438-25311-00-00 and also a carbie for the same model bike thanks.jimson
Re: DT400 TWIN SHOCK REAR WHEEL & CARBIE
« Reply #1 on: October 13, 2009, 10:12:27 pm »
You doing resto, or ride bike?
99.9% sure that a twin shock DT400 uses the same rear wheel as a DT1/DT250A. If you don't have a spare, I've got an ugly-but-functional one here.
Offline jimson
« Reply #3 on: October 17, 2009, 08:11:50 pm »
Thanks Zorroz its worth a look  but its off a mono shock model rear hub is not the same  :( jimson
« Reply #4 on: October 17, 2009, 09:19:58 pm »
hubs are the same as xt500 thumpers front and rear but dt's use steel rims
where xt's have alloy rims
mx250
« Reply #5 on: October 20, 2009, 01:43:45 pm »
There you go Gazza, the choice is your's ;D. One or both ;) ;D.
Both have rust on the rim but still structurally okay I think. Ditto brake surface etc. Rough but usable and free ;D
PM sent.
« Last Edit: October 20, 2009, 01:55:37 pm by mx250 »
Offline jimson
« Reply #6 on: October 20, 2009, 05:54:56 pm »
You are the man! I like the bit at the end FREE  ;D jimson
mx250
« Reply #7 on: October 20, 2009, 07:20:50 pm »
What goes around comes around, hey Gazza ;) :D
