Author Topic: Fox air Shocks  (Read 6458 times)
Offline lyle2212
Fox air Shocks
« on: October 10, 2009, 04:34:47 pm »
Talkin to a bloke at work a while back about old dirt bikes. He off handedly mentioned that he hadn,t owned a dirt bike in 30 years BUT !!! happened to have a pair of almost new FOX AIR SHOCKS sitting in his garage.  Trying not to appear overly excited I casually asked if he would like to sell them and if so how much???!!!!    Oh about $300 was his casual reply. " I,ll take them off your hands" I replied back while trying to hold my over excited composure.  As I recalled  seeing a pair sell on Ebay last year for US $1200..       Anyway what I would like to ask anyone who has a set is ..how much air pressure do I put in them,bearing in mind that I weigh 95kg on a good day, and I would like to be able to pillion my missus  on my Bully Frontera and she weighs about 55kg ,   regards lyle
Re: Fox air Shocks
« Reply #1 on: October 10, 2009, 04:51:38 pm »
You could start with about 80lb in the top chamber and 130 in the lower but it varies from bike to bike depending on the leverage ratio of the rear suspension.
$1200 for a set is over the top when they regularly go for around $300 US on ebay.
Offline frostype400
Re: Fox air Shocks
« Reply #2 on: October 10, 2009, 05:02:35 pm »
i wish i could find some 400mm ones for $300
1971 tm400 and PE's
Re: Fox air Shocks
« Reply #3 on: October 10, 2009, 05:15:23 pm »
Keep looking on ebay US, they are out there. I've got 3 pairs here.
Offline frostype400
Re: Fox air Shocks
« Reply #4 on: October 10, 2009, 05:18:59 pm »
ok thanks will keep an eye out would like a pair or two thanks Michael. :)
1971 tm400 and PE's
Re: Fox air Shocks
« Reply #5 on: October 10, 2009, 07:31:33 pm »
Yeah they are always on ebay, i have  2 pairs. Frosty they are not easy to fit to PE's. Its possible but will cost a bit extra in special made mounts. Also if you want them for the PE, dont get ones that are already 400mm because they will have too much travel and you will oonly have to shorten bodies and shafts anyway. Get some around the 14.75/15 inch mark they will have the right travel and then all you need is longer top and bottom mounts. If you start with a long set you will only need to shorten bodies and shafts which will just be extra cost.
for all Fox Airshox parts and info
see here
http://ltthor.home.comcast.net/~ltthor/FAS.html
and
http://www.stallionmachineshop.com/fox_air_shox
and and older rebuild atricle here
http://home.iprimus.com.au/hyrockpk/Manuals/RebuildingFoxAirShox.pdf
« Last Edit: October 10, 2009, 07:36:46 pm by LWC82PE »
Offline frostype400
Re: Fox air Shocks
« Reply #6 on: October 10, 2009, 08:28:08 pm »
ok thanks for the advice will make sure to get the right length thanks Michael. :)
1971 tm400 and PE's
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: Fox air Shocks
« Reply #7 on: October 10, 2009, 08:38:15 pm »
I know of one lucky chap who bid on some poorly worded 'old suzuki rear shocks' - US$21.00 total to his door.
But you already knew that, if you had read the SHOCKS FAQ.
http://cid-407d7ef0965d3991.skydrive.live.com
   Pure Enduro
     SHOCKS_FAQ.txt
« Last Edit: October 10, 2009, 08:41:05 pm by lukeb1961 »
Offline lyle2212
Re: Fox air Shocks
« Reply #8 on: October 13, 2009, 10:32:23 am »
Thanks for all the info fellas, I just ordered in a few stickers and a Fox Air shocks owners manual from the USA with the website that was provided, much appreciated, regards lyle.
Re: Fox air Shocks
« Reply #9 on: October 13, 2009, 02:13:29 pm »
does anybody have an email address that works for Thor Lawson - everytime I use the one on his website it bounces back?
ta
Rossco
Offline bazza
Re: Fox air Shocks
« Reply #10 on: October 15, 2009, 06:47:47 am »
I have the fox airshock manual if you need settings to start at.Use Nitrogin not air. Pm me if need any info
Embrace patina
Re: Fox air Shocks
« Reply #11 on: October 15, 2009, 06:31:11 pm »
Whats the address on his site, I used  [email protected] no problem earlier this year
Re: Fox air Shocks
« Reply #12 on: October 15, 2009, 07:12:42 pm »
Tony - have tried that twice and it bounces back.
Rossco
